IDX-PRO+VDI
  • Leshka
    [IMG]<a href="http://www.imageup.ru/img216/1146225/2-tone.jpg.html" target="_blank"><img src="http://www.imageup.ru/img216/thumb/2-tone1146225.jpg" border="0" alt="Хостинг картинок"></a>[/IMG]
  • Leshka
    [IMG]<a href="http://www.imageup.ru/img216/1146225/2-tone.jpg.html" target="_blank"><img src="http://www.imageup.ru/img216/1146225/2-tone.jpg" border="0" alt="Хостинг картинок"></a>[/IMG]
    Help!
  • Leshka
    Correctly or not. Please.: Помощь:
  • Davor
    Are you planning something like this?
    Yes. I've tried some UXO detectors in bright sunlight and learned that their leds and other indicators worth a squat when our local star is in zenith. True, a dial can be banged out of it's bearings, but it either works or it doesn't, and you can always tell.
    The whole difference is in analogue vs digital division of the X and Y signal, and a whole bunch of milliamperes.
    I stood aghast when I learned that Raspberry PI draws over 300mA at any given moment. That was only a moment after I learned that it is also crippled on I/O, and a few moments before I started comparing these basic parameters of other popular platforms with micros. Analogue rules!
  • kt315
    no. he is planning something like that
  • Qiaozhi
    I'm thinking of a simple and frugal analogue divider (tangent of the target angle) and after some signal conditioning connect it to a dial instrument.
    It would not make much sense if a digital VDI unit uses less than 10mA.
  • Davor
  • 6666
    anyone interested in analogue "VDI"
    What have you got in mind Davor ?
  • reiv
    Ok, thanks and what was yours values of C1 and C2 ? First You have to measure inductance and insert to this pattern?
  • Orbit
    idx
  • dfbowers
    I used the basic oscillator section for the TGSL below, except I changed the capacitor values to determine resonant frequency of the RX coil.
  • dfbowers
    Originally posted by reiv View Post
    Strange.. For example here is some info about XLT concetric works at 6.5kHz too, and it is 180 degree(sorry it`s not in english) but just look at photos:http://taktykpulse.com.pl/misc/Modyf...0XLT%20cz1.pdf I have 180 and everything: BG,Discrimination works fine,maybe it is the same.. anyway could you show yours Rx oscillator circut? Is this circut will by ok?, what about corect values of all elments [ATTACH]22267[/ATTACH]
    THe schematic you have attached should work just fine for testing resonance of the RX coil.tI double checked my phasing. I scoped the hot end of the Tx coil for Channel 1 and Pin 6 of U1 for Channel 2. Mine definitely looks like 90 degrees. Maybe someone else can offer an option as well?
    Don
  • Davor
    BTW, anyone interested in analogue "VDI" with dial instrument? A Toltec schematic gave me an idea. My reasoning is that it would use very little current and a dial is a dial regardless of sunlight.
    How much current does the VDI use on average?
  • Davor
    Originally posted by Firebox View Post
    Hi DAVOR,
    i have my kit from silverdog. It has a Schematic printed on PCB, but i belive the position of the zener diode is wrong, it must show in the other way...
    So what position is right?
    Firebox
    Eduardo is right. The other option is that your discrimination is set too much "on the wild side" and invites more iron. I recently learned that ferrous materials of very low conductivity tend to respond naturally in a non-Fe quadrant. If that is the case, you may turn your discrimination potentiometer as ever you want - it will stay there.
  • reiv
    Strange.. For example here is some info about XLT concetric works at 6.5kHz too, and it is 180 degree(sorry it`s not in english) but just look at photos:http://taktykpulse.com.pl/misc/Modyf...0XLT%20cz1.pdf I have 180 and everything: BG,Discrimination works fine,maybe it is the same.. anyway could you show yours Rx oscillator circut? Is this circut will by ok?, what about corect values of all elments Click image for larger version
