IDX-PRO+VDI
  • paku
    yes the layout PCB for board
  • Schatztaucher
    What do you want? Black and white pcb? do you mean the layout....?
    the layout is in the thread!
  • paku
    any one have black and white pcb i need that
    i want try make this IDX look like fun detector
  • Schatztaucher
    ok reiv , thanks
  • reiv
    Hi, best way to add 2tones to idx is connect it by a switch like in scheme in #1320 at colector of Q3 in this way You don`t have to change anything. 2 tones indicates all metals rejected by discrimination soe use it all time is torture for your ears. I switch from 1tone to 2tone when I found a target, it is very helpfull to identify rusty iron. About sensitivity of vdi it is hard to improve it, i trayed some things but with no result
    Regards.
  • Schatztaucher
    hi at all,
    I want to build my second idx. This time the board with 2 ton.
    I have some questions for the experts. what to consider? must be changed something at the idx board?
    and a second question: the sensitivity of the vdi is not very high. about 15 cm for an euro. is there a possibility to improve the sensitivity? which are the best for the vdi connections, on the idx board?
    i hope somebody has some answers....
    best regards, marc
  • Schatztaucher
    @ daxxin
    maybe you should post pictures of your board. do you have silver dogs board?
  • Daxxin
    WOWW!! compliments! , atrleast i know blue deep is working ,but mine not yet
    i hear beep only if i move very fast some metal in the center of coil.
    only turning GEB make some difference ,other pots if iturn left or right nothing change.
    Originally posted by Schatztaucher View Post
    hey daxxin....take a look on the coil
    http://www.youtube.com/watch?v=n62sHWQSfvY
  • Schatztaucher
  • gurdal
    Hi
    my idx
    http://youtu.be/qr_cKsiySPk
  • golfnut
    My idx depth homemade 10" DD
    There are lots of air test results availble for kits but few in european soil - taking inspiration from dons ground tests I set up a bed. 1" depth increments, short lawn on top.
    Targets are 0.5" diameter lead balls.
    Disc open 7"
    Disc rejecting nails etc 5"
    I will arrange an AIR and add.
    S
  • ashefr10
    hello, can you replace it with a battery of moist riser card 6 to 12 volts? or you can find on this type of card?
  • Schatztaucher
    i don´t no....but read this!
  • Daxxin
    i´ve just found someting about the 950 deep scan coil......
    http://www.findmall.com/read.php?31,1222083
    Hi do you think BLUE deep scan cannot be used with idx pro?
  • onuba
    poten ground balance
    silverdog poten ground balance is 22k or 25k
