IDX-PRO+VDI
  • Schatztaucher
    i´ve just found someting about the 950 deep scan coil......
  • ashefr10
    I do not know if you can use this head for idx, would you ask a danbower or edouardo
  • Daxxin
    Originally posted by ashefr10 View Post
    hello, U effective Rx seems too high. you should have about 4 mV ac with a multimeter.
    Hi Nico
    u are right too much high rx i get some sound putting something metal in the center of coil , coilis BLUE MAX DEEPSCAN 950 P/N624-0265
    isnt ok for idx? or i missed some mods?
  • ashefr10
  • Daxxin
    i'am testing idx with scope rx and tx seems its working but no audio at all i have check also 400hz still there
    till base of bc547 but at his collecctor conected to base of mpsa13 no signal.
    this what i get ch1 tx coil input and ch2 pin 6 of U1:
    i have try to follow the signal at pin13 of CD4066 i have clear square wave but pin 1 and 2 almost no signal or very small wave.
    what i have to test?
    thanks
  • reiv
    Sorry.. I can`t edit previous post, this is correct
  • reiv
    I have made a little mod of PCB 2tones: smaller(3.5x4.5cm),all connection at one side, center mounting and no wire connector . I know about wett grass problem but i want to connect it by switch like in "schematic" below, soe at wett grass or any hard land i will use 1tone.
    Cheers
  • onuba
    Originally posted by reiv View Post
    Sure this resistance it`s not critical, just helps to get more linear control of volume. With 2k5 you will get start to hear beeping on "1.5" position of potentiometr (with 1-10 scale) and full of volume at "10". Experiment with this resistance and You will see what is all about
    reiv
    speaker is not worth 0.5 w. 8 omh. volume goes well
  • ricalbertvig
    anyone know if the coil of a bounty hunter detector, may be used for this detector?
  • reiv
  • onuba
    Nice working volume control to IDX:
    reiv I can prove it 2k2 resistance
  • reiv
  • onuba
    35cm Very Weak sound, That You can Pass
  • onuba
    2k2 in vr3
    I have put 2k2 in vr3 and one it sees the improvement and pinpoit that This sees beyond, Without the balance sheet of ferrita since I do not have tendre that to search, to coil 8 " concentric 30cm
  • ashefr10
    hello, I put at disposal of the idx 2 videos, the first fashion discrimination and pinpoint the second mode.
