IDX-PRO+VDI
  • maxfly
    VDI signal creep, Help!!
    I need Help with VDI adjustment!!!!
    I have finally found an original Whites Blue Max 800 for IDX Pro with VDI. Everything is working fine with large coin detected at around 30cm, plroblem is that as a target gets closer to coil the VDI number creeps either up for low numbers or down for high signal with +45 being the most stable area. An AU 50c will start out at +26 and end up +45 when very close to coil. The Disc pot suffers a bit of creep but not like that! I though these problems would go away with original coil. VDI numbers start to show on screen at about half the distance that audio detection is made, is that normal?? I have scope ect for testing. nobody seems to have had this issue yet,
    Max
  • Firebox
    i have the problem with large iron objects. The Disc cracks or give some plops, but my original Mi“nelab Musketeer have this problem too. So i belive this is ok ..
  • golfnut
    Do other users of IDX suffer breakthru from large Iron? Small iron I gets disc'd out ok..
    S
  • Firebox
    My Lugatek VDI shows a ALuminium Coin with VDI +70 and Alu foil with VDI +38 - +42
    My Geotech VDI shows a Aluminium Coin with vdi +55 and Alu Foil with VDI -6 - -2
    My XP Deus shows Aluminium in VDI +90 - +98 Silver in +80 - +89
    It would be better when both VDI shows approximate the same value.
  • Davor
    It is the nature of a thin foil to act as a material with very poor conductivity. This feature is your friend
  • holyuser
    Originally posted by Firebox View Post
    Is it possible to set the Aluminum oder Silver in a higher area ( for example + 85) ?
    I suppose that this is not possible
  • Firebox
    i have a geotech VDI mounted on the IDX Pro. Is it possible to set the VDI Values in a higher range? for example Aluminium is detected with VDI +34 / +38, Alufoil is detected with VDI -2/+2.
  • Qiaozhi
    Originally posted by Mefisto View Post
    IDX done by eduardo. Coil 25 cm. 1 euro 40 cm when tested in air. Switch is added for 1 and 2 tonnes. I can not insert pictures.
    You need to make at least one post before you have permission to post pictures. You've just done that, so please try again.
  • Mefisto
  • Davor
    My future analogue VDI is now much closer to its realisation. I have a really good 2 quadrant analog divider at hand with all garden variety components.
  • eduardo1979
    Originally posted by Leshka View Post
    Eduardo1979, I would like to know. Is it correct or not?
    Yes, is correct.
  • Leshka
  • eduardo1979
    Help.
    [ATTACH]22377[/ATTACH]
  • Leshka
    Help.
  • Qiaozhi
    [IMG]<a href="http://www.imageup.ru/img216/1146225/2-tone.jpg.html" target="_blank"><img src="http://www.imageup.ru/img216/thumb/2-tone1146225.jpg" border="0" alt="Хостинг картинок"></a>[/IMG]
    Leshka,
    This is not the way to attach images in the Geotech forum.
    When making a new post, scroll down the page until you see "Manage Attachments". Then click on the button and use the dialog boxes to attach your images.
