IDX-PRO+VDI
  • Schatztaucher
    many thanks!
  • holyuser
    Looks rightly.
  • Schatztaucher
    would someone please check the connections from the vdi?
    Would be super nice if someone would check the connections vdi ....
    Many greetings marc
  • simonbaker
    schematic
    I hope to locate a schematic file for silverdog's pcb, hopefully in ExpressPCB schematic format. If someone can post a link to the most recent version I'd appreciate it.
    -SB
  • dfbowers
    Originally posted by Schatztaucher View Post
    hey don,
    great work .... I hope my idx works as good as yours, if it is ready.
    Perhaps you could also connectors for the vdi mark on the circuit board? I've done it myself ... just to be sure ....
    regards, marc
    Marc,
    I have the VDI Module on order from Silverdog, so I will update the diagram when I get mine running. I could in the meantime update it based on what others have documented earlier in the thread.
    Don
  • Schatztaucher
    hey don,
    regards, marc
  • dfbowers
    IDX Quick connect diagram
    Don
  • golfnut
    The bottom one will be wideband (low Q) low R low output more BW
    Top one will be narrow band (Hi Q)
  • dfbowers
    Originally posted by Wiltran View Post
    Don, just to be sure I understand you, are you saying that the 324 should not be used?
    Also I would like to do your tgsl sensitivity upgrade to my IDX, please could you post the schematic changes to the IDX and new connections thanks.
    The LM324 should work just fine. Actually, the LM324 seems to be less noisy than the LF347 but I have not tried a handful of them yet. I have only made my observation base on 2 ICs.
    Just so happens that my LM324 had an output offset of - .010V !!! With the offset being so far negative, it had a long ways to go to trigger the LM393s, so sensitivity appeared to be not so good.
    By adding the mod documented earlier in this thread, it allowed me to adjust the reference voltage slightly negative to get closer to the output levels of the LM324s. It's a great fix.. Same idea that I used with the TGSL.
    The offset from the LF347 that I am using now is as close to 0V as I can measure. This makes the mod unnecessary. Just choose your ICs wisely and you should not have a problem.
    Don
  • Wiltran
    Sure enough.. This was a "bandaid" approach. I replaced my LM324 with an LF347 and that cured my bad offset problem.
    Don
  • dfbowers
    I finished the IDX kit from Silverdog, minus the VDI module as I do not plan on using it.
    Everything works fine, but I was looking for more. With the stock 9.5 coil from my XLT, I could only detect rings and coins to about 25cm. Then I realized that the offset on pins 1 & 14 of U3 was a mV or 2 below ground potential. The signal just has too far to go to trigger the inputs on U4!
    I am using the LM324 from the supplied parts from silverdog instead of an LF347. In looking at the specs for the LF347 is can have an offset as high as 5mV!!. With no way to adjust the offset of quad op-amps, I just implemented the same fix as I used with the TGSL. It allows you to adjust the reference voltage slightly negative so the LM393 can trigger earlier. This brings the detection range to 40CM for coins and rings,, the ragged edge of the detection range for the stock 9.5 concentric coil.
    This may be a band-aid fix and may be a symptom of another problem, but I'm not sure what. I just figured out a fix..
    Don
    Don
  • dfbowers
    Hi Don,
    The series resistor is to fine adjust the RX phase. It also raises the Q of the coil. Nothing to do with nulling. Which is mechanical. White's did put a high mega ohm resistor between the TX and RX windings which I never understood. I guessed it was for static dissipation? Maybe nulling.
    Make your windings matching the inductance then add a resistor in series with the RX to equal the original total of 111 ohms.
    I'm in the process of winding a pair of DD coils..
    Can anyone comment on the general layout of the RX coil?
    Thanks..
    Don
  • 6666
    Thanks Kilner
    I had been fiddling with the C1 C2 buttons on the bottom of the view screen
    when the program starts up
    and nothing was changing but now I see when you press file, print
    a whole new screen appears and from there you can select what you want to print
    with C1 C2 etc, well I hope somebody else trying to figure this out will see this, I am embarrassed now
    but glad I asked
  • kliner
    Just ask it to print then you"ll see that the tracks are black and you can select/deselect other layers for printing on the left, you want C1 or C2 (copper layers)
  • 6666
    Ok here is todays dopey question
    I just got a nice new shiny laser printer
    and I want to try this hot iron transfer method to make a pcb
    so i thought I would try the Idx pro , pcb for first try.
    But is there a plain black and white pcb ?
    Looking through this thread there are a few lay files
    I have a lay file viewer, but in it the pcb's show up as a black background and green tracks
    with all the components, and I cannot seem to be able to just get
    the tracks to show, so i can print just the tracks
    So whats the trick ? I hang my head in shame.
    thanks
    6666
