IDX-PRO+VDI
  • der_fisherman
    Originally posted by lutek View Post
    I like your small dimension board but not the expense of mounting holes. It would be nice to have four holes, instead of two. All user interface board are exposed for mechanical stress due push-button or encoder activities.
    What I often do (with or without mounting holes in a PCB!) is to put a spot of hot melting glue at each corner and press it onto some part of the inside of the box or similar.
    It holds well but the hold can be broken with careful use of a screwdriver or similar if needed......Does not need any metallic hardware like screws, nuts and standoffs, nor do I need to drill holes, which may be a problem anyway with certain sensitive designs....
    For me its the perfect answer to the problems of mounting PCBs inside (usually) plastic boxes.
    Note, if it doesn't stick, clean with Meths/Denatured alcohol first.
    Andy.
  • lutek
  • Fabian
    Smaller VDI PCB
    Hello! Here is the PCB of the VDI in 5x5 cm in case anyone needs it. I do not know if it is very small and if the proximity of the tracks can be a problem. Please DO NOT USE until check that everything is correct, I think so, but I'm only a hobbyist and I can have made a mistake (which I do appreciate you letting me know)
    Well, that's all.
    ¡Hola! Aquí va el PCB del VDI en 5x5 cm en caso de que alguien lo necesite. No sé si es muy pequeño y si la proximidad de las pistas pueda ser un problema. Por favor NO USAR hasta tanto comprobar que todo está correcto, yo creo que sí, pero sólo soy un hobbista y puedo haber cometido algún error (que agradeceré me hagan saber)
    Bueno, es todo.
    Saludos
  • Lefizz
    That looks great. Tell us more
  • 6666
    Originally posted by elbombaci View Post
    elbombaci
    this looks like a very good project, thanks
  • Uykusuz
    Hi
    This is my new project:
    I will share all documents as soon as possible.
  • selim
    Hi ivconic
    Do you have knowledge of coil winding
  • Qiaozhi
    Originally posted by sadeg-f View Post
    hi holyuser and thank you for everything
    i cant find PIC16f88 in my country
    please recompile the VDI to PIC16f84
    The PIC16F84 does not contain any A2D converters, and therefore cannot be used with the VDI circuit. I cannot believe there are no PIC16F88 ICs in your country. It is a very common device.
  • sadeg-f
  • Fabian
    My IDX-PRO PCB´s
    Some pictures
  • Mullihaka
    Originally posted by eduardo1979 View Post
    It is my IDX-PRO. The circuit layout is the last file I posted and working properly. The penultimate does not work. I have no schematic, I have only Layout.
    That is what works.
    Hi Eduardo,
    For some reason, I can't open this RAR file. Can you check if it is OK? I mean the file with the two tone modification.
    Thanks!
  • der_fisherman
    LCD Infos and interfacing
    Originally posted by shansov View Post
    Tell me where the first contact?
    You can find a lot of extra LCD information here:-
    although the site is for PICAXE fans first and foremost, it may give more good ideas to anyone seeking LCD infos.
    andy
  • Fabian
    Of course..!
    Good Job
    With your permission I may use it, it will make for cheaper boards
    Silverdog
    Of course you do! It would be an honor for me, but the credit must be for Eduardo and his excellent work.
    Best regards
  • silverdog
    Originally posted by Fabian View Post
    Hello people! I adjusted the final circuit made by Eduardo, to make it fit on a 5x5 sheet of fiber, which is the standard that I get in my city. Here I share it, maybe someone needs it.
    Good Job
    Silverdog
  • shansov
    Thank you very much.
