Originally posted by shansov
IDX-PRO+VDI
EDU two tone board
Has anyone got the EDU IDX pro two tone board working? Mine works ok for steel- deep tone, but when I try non ferrous such as a penny, quarter or dime I get one half the depth that i got before and terrible static.http://www.geotech1.com/forums/image...milies/mad.gif
Hello SilverdodgOriginally posted by silverdog View PostI'll measure resistance when I get home tonight
I tried Ivconics 330nF and 33nF, it didn't seem to be right
Is there a scope picture on here somehwere that will help me set RX correctly ?
Here is a photo of the cancellation coil, my IDX_PRO
RX seems to work best near 90 degrees as in the photo.
16 volts for TX, 2 volts for grid
+ or - 150 mV for RX, 50 mV per grid, pin 6 of 5534.
Greetings JoseAttached Files
Originally posted by mikebg View PostSilverdog, what is resistance of TX and RX windings in your Fisher coil?
For Fisher 27cm search coils; RX-capacitor=33nF and TX-capacitor=330nF.Regards!
Capas for Fisher
Silverdog
In one of Ivconics mails he says what values of capa to use with the Fisher coil
Just obtained one of these Fisher coils, I measured TX=1mH RX=6.98mHOriginally posted by ivconic View PostRX cap can be critical to tune up closely.
Generally it is close to 0.033 (33nF). But if you put just 33nF that will not do.
Better put 22nF + .... in parallel , close to 33nF..
Be patient and give it chance, try to tune it as closest as possible.
Once tuned - hell of detector !
Deepest from all hand made presented here on Geotech forums.. no competition at all!
How do I calculate the correct caps ?
Thanks Strujas, You´re right. I corrected it already.Originally posted by strujas View PostFabian you have one little mistake on your board. R3 need to be conected for other side of R4.
RegardsAttached Files
4 holes
Originally posted by lutek View PostI like your small dimension board but not the expense of mounting holes. It would be nice to have four holes, instead of two. All user interface board are exposed for mechanical stress due push-button or encoder activities.
I had thought some kind of solution that Andy gave to fix the board. Either way, it was not a big deal to add two small holes more (There´s no more space
). They are asymmetric with respect to the others, but they are there. Now is your problem.
Here goes, with other minor design fixes.
Best regards
FabianAttached Files
