Originally posted by scrungy_doolittle
Discrimination is traditionally done in motion mode, not because it is not possible to do in non-motion, but because of 1/f noise and drift that spoil your calculation. The other benefit of motion mode is that you are amplifying the target response without the cyclostationary air signal. So in effect by reverting to motion detection you are considerably improving the dynamic range towards the low target responses, and a simple ADC built in a micro can do.
What you are about to do is pack a full signal span and process everything in a micro. Therefore you need a good ADC with at least 16 bit resolution or better because the targets are found somewhere around LSB. And a bit of luck.
I understand the I/Q ratio a bit better, but getting the I and Q numbers to start with without using analog (the goal in my case is a pure digital, just digitizing the transmit and receive signals, and then deriving the rest with the micro) means computing the I and Q if you will. And that, is a miminc of a traditional vlf. Only in software. I've not been on for a while, been very busy dealing with an impending divorce, and work on top of it. Game changer when the wife left. Now I have to get an automatic cat feeder to feed the outdoor cats when I have to travel. So that is my current project. Arduino based, using a RTC and motor drivers. Got all the pieces now, so trying to get the motor part running... canibalized some old copiers and printers for motors. Should be easy with the .99 motor driver boards off ebay, but no joy at the moment. Haven't swung a loop for much time either. Used to be a daily thing. Now, no time to speak of. Did get to coin shoot for an hour or two in Dallas on a business trip. Love my old Whites 5900 di pro, but really want a deeper machine that is computerized.
