IDX-PRO+VDI
  • h9361
    Here is the pcb Eduardo two tone idx in smd checked and works!
    Hello
    Dear Sir
    Are you using TL074 or LF347 or etc?
    I adjusted my resonance frequency and removed ferrite very nice and its disc for IRON is excellent.
    But as soon as putting it inside of box, its disc is not true.
    I used TL074 and TL064 with different brands, all of them first is ok but after a time, its behavior is changed.
  • eduardo1979
    Originally posted by h9361 View Post
    Hello
    Dear eduardo
    Please see attached, red circle.
    In schematic, the diode is revers.
    Is that true?
    Hello. If you use a 1N4148 diode, the orientation is correct, but if you use a 2V7 Zener diode, you have to put it in backwards.
  • h9361
    Originally posted by eduardo1979 View Post
    The discrimination of the low tone of the iron is done through R43, which is connected to the LM393 comparator circuit. Don't worry, the circuit works as is.
    Hello
    Dear eduardo
    Is that true?
  • Aleks85
    Hi, maybe this information will be of some help, I didn't do this myself.
    First, the original text in Russian, followed by my translation using an automatic translator.
  • Vikas Kumar
    You guys have started modifying displays, while I still haven't managed to wind a coil. Could someone tell me which wire gauge (SWG) and how many turns are needed for the RX and TX windings of a D-type coil? I want to build a 32cm D-type coil.
  • mazixx472
    I installed one of these boards in my IDX; everything is fine, and it works with all detectors featuring X and Y channels. It’s a fully functional version, but only for 100 startups—after that, I have to reload the hex file. My question is: is it possible to get the original file somewhere?It is built using an ATmega16.
  • Orbit
  • Orbit
    Eduard's two-tone scheme works perfectly normally and correctly! So that you have no need for other variants, it is important to understand the scheme and connect it correctly!
  • h9361
    Hello.
    Here's a schematic I designed many years ago, and everything works perfectly, just as you want. It has a trimmer that allows you to adjust the level of iron discrimination. Hot stones and minerals aren't detected with any tone; only iron registers a low tone, which increases as the discrimination level is raised. Non-ferrous objects register a high tone. This detector is exactly what you're looking for. The circuit is 100% correct and tested.
    I wish you much success.
    Dear eduardo
    please forgive me for my asks.
    Can i replace bc558 or bc557 for bc639?
  • h9361
    Thanks.
    About your words " I can tell you that when the detector's main Discrimination potentiometer is in the minimum position, the low tone (the iron tone) doesn't work."
    If you put main disc in minimum position, so high tone always on.
    As you know, ( if i remember) ferrous metals cause increasing amplitude of RX frequency.
    Your Iron part exactly check this amplitude voltage and uses a threshold pot for this voltage changing.
  • eduardo1979
  • h9361
    In principle, it should work fine by adding the BF245, or a J113 as well. If there's any compatibility issue, you could add a 100K resistor in series with the JFET's gate. Regarding the operation of the two tones, I can tell you that when the detector's main Discrimination potentiometer is in the minimum position, the low tone (the iron tone) doesn't work. Only the low tone works when you start increasing the discrimination potentiometer level. Then there's a VR2 IRON trimmer, which is used to prevent minerals from registering.
    Dear eduardo,
    I checked your schematic, there is not any connection between main DISC and Iron tone.
    I think Iron tone work independently, are you sure?
  • h9361
    Thanks.
    As you know, Audio frequency of IDX pro is near 400Hz.
    schematic of #4412 (added your Iron pot), if i add your low part to my IDX, Can you tell me what my low frequency will be? exp, 200Hz or?
    See attached, Audio frequency of your schematic and IDX pro.
  • eduardo1979
    Thanks for your nice schematic.
    As you know, i have built IDX PRO and i am trying to add it a second tone.
    I checked your schematic and tried to get only its second tone part, it is attached.
    Is it possible to check it whether it has any error or not?! I want to make your IRON part as a separated PCB for my IDX.
    I have a question about Discrimination of your schematic. In your model, we have two pots, one for DISC and one for IRON.
    Suppose, i adjust DISC to point that it does not detect Iron. Then, i adjust Iron pot so that it does not detect ground, only IRON. Other words, it acts like a threshold for IRON or minerization?
    Click image for larger version Name:	finaltwoTones.jpg Views:	0 Size:	427.4 KB ID:	452320
  • h9361
    Hello.
