Hello everyone, I want to build an IDX Pro metal detector, but I am confused about the PCB versions.
Which is the final stable PCB layout (single layer) that is suitable for printing and etching?
I am looking for a black & white printable version (1:1 scale, mirror if needed).
Also, what are the exact PCB dimensions?
Thank you in advance!
IDX-PRO+VDI
Originally posted by HaaKaaN View PostFriends, can you help me? I assembled and tested my IDX Pro metal detector, then I built the 2-tone sound circuit and connected it correctly to the connection points, but it keeps beeping. Could someone please help me with this?1 Photo
- Likes 1
The shield is a shield, the signal wires should not be connected to the shield.
Hello friends, I wanted to ask about the coil in the circuit you shared, Aleks85. Is it DD or concentric? I didn't understand the GND wire coming from the coil; is it shielded before being connected to GND? Finally, thank you for the PCB and measurements.
Please read the forum rules -> Basic Rules of the ForumsOriginally posted by Alikkc View PostMerhaba arkadaşlar Aleks85 usta paylaştığın devrenin bobini soracaktım dd mi concentrik mi balıktan gelen gnd ucunu anlamadım ekranlama yapılıp mı gndye bağlanıyor son olarak pcbsi ve ölçüleri varmı teşekkür ederim
eduardo1979 Hi Eduardo, could you help me with my two-tone circuit? As you suggested, I removed the R55 resistor and made the circuit connections correctly, but when I connect the BC517, it constantly beeps, as if it's detecting something, but it keeps making a sound and the BC517 burns out. What could be causing this problem?
I'm just starting this project and I've learned so much from you. Thank you for helping people.Originally posted by eduardo1979 View PostHello. I found this Russian forum of IDX-PRO PCB. The PCB had many mistakes and failures of some components. I corrected the PCB and added the missing components. I wish that we all take a look and give a chance on this project. Surely here in the forum there are people who would be interested in this project. I've also found the VDI file with all documentation. Please advise if there is any error in the PCB. I'll put here a video of this VDI I found on Youtube. Thanks for reading. Eduardo.
- Likes 1
Hello friends im looking for good version of idx pro to bulid and i found this eduardo1979 idxpro+vlf but there is many posts and updates for this project i need to know which one is correct or any one here can provide a correct version like idxpro with two tones, i just want to avoid wasting time bulding wrong device. Greetings
