IDX-PRO+VDI
good afternoon someone help me how do I measure the coil frequency with a multimeter with a 20mHz frequency scale
My IDX PRO, neither the GEB nor the DISC works. Sensitivity I can barely distinguish. I need to configure it correctly, I am going to reconfigure the coils. I have only run it for the first time without seeing if the frequency in TX has changed. I detect all metal and ferrite but as I said before the GEB and the DISC do not work.
When I ran or turned on the IDX PRO for the first time I did not get any audio. I was surprised that it worked with some LF347N, you have to be careful at this point it seems to me that there are ICs that do not work as they should be.
I have just finished building the IDX PRO and I have used the coils mentioned by Eduardo.
What are the measurements of your Uilian950 coils?Originally posted by Uiliam950 View Postgood afternoon bgm would you have the construction data for the idx pro home coil?
the frequency and inductance that the coils should be
I did mine, but I can't adjust it in (gb) (disk) (sens) only in (tresh) the adjustment I don't know what's wrong
good afternoon bgm would you have the construction data for the idx pro home coil?Originally posted by dgm View PostIf you start to assemble the components on a pcb you have to continue to do it as per the scheme you cannot make changes. Different pcb for idx have been made, each one with different assemblies and modifications.
good afternoon bgs would you have the construction data for the idx pro home coil?Originally posted by bgs View PostIt is different when the object is in the ground. So far no one has dug a coin more than 25 centimeters
if I do not connect the pimpont wires on the pcb it will work as if it were always with the pimpont on?
Guest repliedIt is different when the object is in the ground. So far no one has dug a coin more than 25 centimeters
good night I took a look at my pcb I replaced the components that were wrong but unfortunately not much has changed still arriving only 20 centimeters in an outdoor coin can it be the coil?
Why did you remove the diodes? If there are in the scheme you have to put them back. I have already said and reiterated to work you have to find the components installed by mistake.
