Originally posted by deemon
2Midas
Yes , I have the same thought now ... but I really did it for some purpose . This design did have a three main goals - to test this "current-reverse and recuperation" concept , to test some specific schematic solutions and to test a ferrite as a search coil core . What does we know about ferrite ? It has 2 main drawbacks - magnetic instability and nonlinearity
And these drawbacks makes almost impossible to use it in high-class metal detector . On the other hand , ferrite search coil looks quite attractive in some specific conditions , such as hollows , caves , fractures , etc . And what is interesting , it seems that this circuit is the one and only that can use a ferrite quite correctly and push it to the limit .
What I mean by this - it's instability and nonlinearity cannot make a harm here . You see , when the current is changing in the coil ( charge and discharge intervals , A-B and D-E on timing diagram ) - we don't measure anything , and when we measure the incoming signal ( measuring interval C-D ) - the current doesn't change
When we receive , the current is constant , we are sitting on the one point of the magnetization curve , so if the permeability does change , it's not a problem at all . Even if the permeability of our ferrite drops to 1/2 of initial value - it can't disturb the demodulation process of the circuit . All we need from our ferrite core is to "suck" magnetic force lines into the coil , and it's enough ...
So I cannot stop myself to try it anyhow and look how can it work . What about the concept - it works OK , so the schematics does , but about ferrite I am hesitating now
. As I think - this performance of course isn't the best because of mediocre quality of the ferrite that I used ( and the core isn't monolithic , it's not good too ) , but what can I achieve when I use the best ferrite - it can show the future experiments , of course .
So the best idea now is to assemble the same device with the same schematics , but optimized to use a conventional search coil ( simple round coil with air core ) - it needs some minor changes in the power chain circuit , and direct compare it's performance with the existing one . And if I find the good long ferrite core with high permeability and good Litz wire , I will be able to replace my search coil in this device and compare them again in order to make a final conclusion .
And these drawbacks makes almost impossible to use it in high-class metal detector . On the other hand , ferrite search coil looks quite attractive in some specific conditions , such as hollows , caves , fractures , etc . And what is interesting , it seems that this circuit is the one and only that can use a ferrite quite correctly and push it to the limit . What I mean by this - it's instability and nonlinearity cannot make a harm here . You see , when the current is changing in the coil ( charge and discharge intervals , A-B and D-E on timing diagram ) - we don't measure anything , and when we measure the incoming signal ( measuring interval C-D ) - the current doesn't change
When we receive , the current is constant , we are sitting on the one point of the magnetization curve , so if the permeability does change , it's not a problem at all . Even if the permeability of our ferrite drops to 1/2 of initial value - it can't disturb the demodulation process of the circuit . All we need from our ferrite core is to "suck" magnetic force lines into the coil , and it's enough ...So I cannot stop myself to try it anyhow and look how can it work . What about the concept - it works OK , so the schematics does , but about ferrite I am hesitating now
. As I think - this performance of course isn't the best because of mediocre quality of the ferrite that I used ( and the core isn't monolithic , it's not good too ) , but what can I achieve when I use the best ferrite - it can show the future experiments , of course . So the best idea now is to assemble the same device with the same schematics , but optimized to use a conventional search coil ( simple round coil with air core ) - it needs some minor changes in the power chain circuit , and direct compare it's performance with the existing one . And if I find the good long ferrite core with high permeability and good Litz wire , I will be able to replace my search coil in this device and compare them again in order to make a final conclusion .
Midas
And about "production complexity" it's a funny argument , as I think - just open any computer or plasma TV , you'll find much more parts inside
