3D treats
  • MartinB
    Shaft Connector
    Hi bernte_one
    This connector is for joining a 21mm OD carbon fibre tube to a 24mm OD carbon fibre tube to make them telescopic.
    If any one has a better solution please post.
  • MartinB
    can you put all as stl files in one zip container? thx
    Hi bernte_one
    Zip file will be uploaded shortly
  • MDfanatic
    Gurdal thank you very much for the files, greatly appreciated.
    Indeed that's a fantastic amount of work.
  • MartinB
    Originally posted by gurdal View Post
    Hello there
    is an excerpt.
    Dosya.tc, dosya yükleme ve paylaşım platformudur. Her türlü veriyi (dosya, resim, müzik, video vb.) saklayabilir ve paylaşabilirsiniz. Tamamen ücretsiz, üyeliğe gerek yok. Hiçbir limit yok. Dosya Upload. Dosya Paylaş. Dosya Yükle
    Wow. That is a fantastic amount of work.
  • gurdal
    3D Hybrid Mixed
    Hello there
    is an excerpt.
  • gurdal
    Hello to everyone
    Is there a GR 2018 box stl file?
    Yours truly
  • bernte_one
    Originally posted by MartinB View Post
    [ATTACH]54437[/ATTACH][ATTACH]54436[/ATTACH][ATTACH]54434[/ATTACH][ATTACH]54435[/ATTACH]
    Here are the various parts for a shaft connector. The small clip on the block attaches to the hinge pin on the arm. I used a cut off nail for the pin.
    I have sent them as sketches so that you can easily manipulate them to suit your own requirements
  • MartinB
    Shaft Connector
    sleeve 3.zipsleeve 1.ziparm 1.zipnew block 1.zip
  • Tibuck19
    Give me a few days to get all the files together, and ill upload STL files for a 6 8 10 and 12 inch coil that most can print on a 200x200 build plate, You ll need to print in abs so you can put all the parts together with acetone and sand it down and wipe with acetone to make it look good, they art only for mono loops though. here a few sample photos of the coils nearly or in some cases finished.
ID:	359043 6 inch coil almost finished in that photo
ID:	359044 Click image for larger version
ID:	359045 8 inch almost finished in those photos
ID:	359046 Click image for larger version
ID:	359047 10 inch
Name:	fix 22 April 19_001_01.jpg
ID:	359048 a ten inch and a 12 inch that i had started to put together.
Name:	10inch coil v8.jpg
ID:	359049 how they get assembled more or less
  • gurdal
    Thank you so much
  • bernte_one
    Many thanks
  • Op04
    And here and here
    I even tryClick image for larger version
  • Op04
    No, but you can see Sergey design and download all the files here and here
  • bernte_one
    Originally posted by Op04 View Post
    Thanks for shared to all for above uploaded..These are so beautiful,,,
    I'm looking for 3D .stl file bolt & nut like this one, does anybody has it?[ATTACH]54214[/ATTACH]
    are you the guy from russian forum who produce detectors based and eddies pitone project?
    can you share you enclosure files and grip, armrest pieces?
  • Op04
    That looks like a toilet seat bolt, check the hardware store.
    Genius! Thanks Guru
