3D treats
  • #31
    Originally posted by Op04 View Post
    Ear for coil
    Do you have a 3D printer?
    • #32
      Originally posted by MartinB View Post
      A bit bulky and too much metal.
      The metals shall be removed, exchange with nylon bolt n nuts. Alternative for ears, can applied before pouring resin.
      No, I don’t have. I put here coz it related.
      • #33
        If you would like, I can send you a printed clevis which is designed to take a Minelab shaft connector.
        • #34
          Hi MartinB,
          Thank you for your help, but I have to refuse because I can make it here easily even though I have to hire a 3D printing service. Besides, I live in SEA, the fare is decent. So thank you ...
          • #35
            Hi MartinB,
            No problem. Always here to help
            • #36
              I can't seem to find a 3D model for collapsible pipes, if anyone has anything I would be extremely thankful.
              • #37
                Hi
                My filament supplier has advised me that 3D printed stems are unlikely to be strong enough.
                You will be better off using carbon fibre tubes which are stronger and lighter.
                • #38
                  Depends on the print orientation, if you print it horizontally it will be strong enough but the supports might be a pain to remove.
                  • #39
                    You could always try a square section tube then you only need to worry about internal supports. If, like me, you only have a small bed, then you will have to print quite a few sections and glue them together
                    • #40
                      Concentric Coil Experiment from ITMD
                      Page 134 of ITMD gives a really nice example of an 8" concentric coil design so I thought I'd have a bash at doing a 3D print of a suitable former.
                      If anyone is interested I can post the .stl file or the Freecad design file
                      • #41
                        [ATTACH]55358[/ATTACH]
                        The stl would be handy thanks.
                        • #42
                          Concentric STL
                          Here is the STL, it's probably a good idea to use supports when slicing.
                          concentric_8inch.stl.zip
                          • #43
                            [ATTACH]55363[/ATTACH]
                            Please could you also post the FCStd file for FreeCAD?
                            When I load the stl file in Repetier Host, it says that the model is non-manifold (i.e. it's not watertight) which may cause a problem during slicing.
                            • #44
                              Concentric Freecad file
                              No worries.
                              There is a spreadsheet within the Freecad design which has the adjustable parameters if you want to tweak it.
                              I use quite a small grommet so you may want to enlarge the hole.
                              This is about the biggest I can get on my Ender 3 printer..
                              concentric.FCStd.zip
                              • #45
                                No worries.
                                [ATTACH]55364[/ATTACH]
                                Thanks.
                                I've never used the spreadsheet option in FreeCAD, so now I need to go and read the manual.
