Ok i the coil has been wrapped in insulation tape and i have even stood in the middle of my garden with it beeping for no reason. When i turn the delay pot all the way to one end i get a click (end of the pot) then if i slowly turn the pot i get a BEEP (to signify the start of adjustment?) then after that i get a random BEEP then nothing and again a random BEEP then nothing for the rest of the adjustment.
Barracuda Legend Kit Problems
Sounds like you may have a bad delay pot. Try unsoldering it and with your dmm in resistance mode and it between the center terminal and one of the outside thermals. The resistance should vary smoothly as you vary the setting from end to end. If it jumps the pot should be changed.
It is also possible that the damping resistor ( the one across the coil) is bad or the wrong value. Check this with your dmm. You can test inside just keep the coil away from metal. If you have an under damped coil it will ring and can cause these problems. Under damping is caused by the damping resistor being too high of value or a poor solder joint. They also can fail open due to too much current.
The coax ground will do most of signal shielding. The coil may be polarity sensitive if there are significantly more windings on the outside of the coil they will act as "self" shielding. If the coil is just randomly wound the coil polarity itself may not make much difference.Originally posted by Impulse View PostI will get some coax tomorrow and try that but i do not have a shield (yet)? also how does the polarity affect the coil as it is a mono loop 'bunched' coil?
Re: Eric Foster PI Search Coil Wire
Posted by: Eric Foster [ Send a Message ]
Date: November 25, 2012 02:15AM
Moderator
Hi Sven,
The orange cable is a specially made RG58 coax. It is made for the offshore industry, specially for underwater use, with a polyurethane outer jacket rather than pvc. This is much stronger and hard to penetrate by contact with sharp edges. Water at pressure would very quickly siphon along ordinary coax if there was even a small cut, and enter the coil windings. Salt water would write off both the coil and the cable and even enter the electronics unless a water blocking connector was used. Of course the orange coax is considerably more expensive, but I thought it was worth it as even for shallow water work it gives added protection.
Eric.
