Baracuda broken
  • #91
    ok. then will begin again from start.
    1. you do not have DC voltage on a base of the darlington transistor
    1.1. disconnect the base from the schematic and connect it on PLUS power via resistor 10-100kOhm. you must hear the sound
    2. you do not have modulated signal from generator
    2.1. check the signal by o-scope.
    • #92
      I had a signal on the MPSA13 ....
      But I was so angry that I destroyed the board, now I have to start from scratch.
      When first turned on the 1054 smoked, I do not know why, I could not find a cause for it ...
      • #93
        If this test is correct, all my 2N5485 are useless, I bought them in China
        • #94
          I've rebuilt the circuit and the problem is the same again - now I'm at a loss as to what could be the cause.
          40106 I have exchanged, BF247 installed .....
          Does somebody has any idea?
          • #95
            Can you make a picture of your pcb from both sides?
            Im not sure but google says BF247 is NFET , are you sure that you can use it as a replacement?
            • #96
              Are all the supplies working
              78L05 output 5V
              IC7660 output -12v
              79l05 output -5v
              Does the main FET get hot or warm after a few seconds of use
              • #97
                Yes , they are working.
                The IRF gets beetween warm and hot
                • #98
                  rebult what? did Qia's mod?
                  • #99
                    Yes i did and the mod you've shown , too.
                    • try do an album and put detailed photos. some hottie serbs has write that sunlight. ok. sunlight, people.
                        sunlight People?????????????
                        • He means that you should go outside with your board and make pictures in direct sunlight. Not inside with flash or Normal electic light.
                          For better quality.
                          • Ah, oke
                            • Today I tried again to find the mistake, but I can not find it.
                              I'm very frustrated, the last two circuits I've built
                              have worked immediately and now that ......
                              • Do you have minus 5 volts ?
