BARACUDA-Legend-1
  • kt315
    40106 burnt. reconnect resitors on GND (+E for 40106) - look this pic. change values of them - look the pic.
    then change 40106.
  • chuubaba
    I fully agree with you. I am 40 now. Too many tasks to look after. I have already been into too much study. My stage of reading to learn has just elapsed and whatever is left is occupied with more pressing priorities. After attempting to find and read about my problem I post in hope for receiving tips from people of knowledge. I wish members stop getting annoyed by my questions. About Kt i am sure he has a big tribe and glorious ancestors so he does not get annoy.
    I already have ... several times.
    Forget about building any MD projects until you understand some very basic electronics. When you've managed to do that, your life will become less frustrating.
    I know that everyone has to start learning somewhere, but you need to try and help yourself, and not rely on others (particularly KT315). I've now lost count of the number of failures, but surely this must a record.
  • Qiaozhi
    Originally posted by chuubaba View Post
    I have tried everything in my knowledge and its time for experts. Why don't you look into these symptoms and suggest a cure.
    This is the last I'm going to say on this subject. Now it's up to you...
  • chuubaba
    Kt brother i am also fail in test # 5 of build document. NE5534 pin6 is constantly giving 4.48V and not changing with trimmer.
  • chuubaba
    ... and so the saga continues.
  • Qiaozhi
  • chuubaba
    There is nothing for o-scope and multimeter in collector of 2N2222. 0.01V
    put pic from collector of 2222 (2n2222) under driver mosfet on your pic of board
  • kt315
  • chuubaba
    Kt you want me to turn the MPSA13 / MPS102 ?
  • kt315
    also we know modulated mosfet Q7 setted unright still in original board. its in inverted position. i did not correct that in my board and left as-is because i did the copy
    hoping correct after testing and in second batch.
    but... this works. you must know this fact. all mosfets are working in inverted position or not just the time will show that.
  • chuubaba
    scope setting is 0.5mS/Division and 5.0V/Division. There was no signal on o-scope. There is no voltage on multi meter. I switch it ON/OFF again and it gives 0.18V on multimeter.
    you do not have modulation signal. give o-scope signal pic on base of 2SA13.
  • kt315
  • chuubaba
    there is one very very small click sound when i switch the power ON. I used 10K 1/4W resistor.
    yes. blue correct. do.
  • kt315
  • chuubaba
    This is my third time (failure).
    Originally posted by Tibuck19 View Post
    You recently put together one ??
