Originally posted by kt315
BARACUDA-Legend-1
You recently put together one ??Originally posted by chuubaba View PostBuilt yet another apberg baracuda as per post #49. Using bench power supply 12V. The +5.02 on 78l05 and -4.95V on 7905. Got -4.96V on pin7 of 40106 but still no detection or sound. Any suggestion for further testing or diagnosis?
i give same pic 100th time.
you MUST hear the sound.Attached Files
Kt only 9640 is little hot but all other components are cold. I have checked many times and there are no short circuits.
one russian bought from me delta board pcb recently. and wrote no sound. R44 was hot. i answer him how to check the sound part.
he did not see. he also checked NE555 set another one with same result. then i did suggest to check EVERY PIN of the socket of NE555 on EVERY PAD and EVERY PINS TOGETHER ON THE CONNECTION.
voo a-la. he answered he fixed the problem - one pin of the socket was closed with neighbor one on top side and that was INVISIBLE - !!!
now he testing DP in field with big ramka coil.
Yeah, that's the problem. I've got bare boards only. I do check of each component before i fit it and will do it anyway, however if such selection should be done i have to buy extra components to have where to choose from. Thats the main reason i'm asking.
I am rather sure the components supplied in the kits from Silverdog are thought out and well selected by everyone one that worked on the upgrade. you should be more then fine with what is supplied, along with the board if you go for the kit form.Originally posted by nonkapo View PostWill do for sure
. Surf already waits for coil and project box. However before I start assembling the barracuda's passive components I want to ask are there any critical components which should be chosen with the nearly identical parameters, same way like the resistors and capacitors in the integrator circuit of surf? Any trannys with the same gain etc? Thanks.
Will do for sure
You did great jobOriginally posted by kt315 View Posti opened thread for begginers http://www.geotech1.com/forums/showt...-power-control
also: http://www.geotech1.com/forums/showt...ng-iron-to-buy
i opened thread for begginers http://www.geotech1.com/forums/showt...-power-controlOriginally posted by Andi68 View PostYou learn soldering with practice, not with watching videos
