BARACUDA-Legend-1
Btw, my built only detect a motion coin, when still it will have no sound at all, i have read some of back there about motion non motion switch... how how?
Thanks for the reply koala, I use metal 2N2222A, i already use 3 coil like on the pi list but dont change anything.Originally posted by Koala View PostDid you use a metal can 2N2222 or plastic. If plastic check if its a PN2222A/2N2222 or a 2N2222P as the pin puts are the opposite way around
not on a computer that I can check you coil parameters on but sounds a bit light on turns. Original coil was 450uH and that is what the damping resistor is designed for.
All resistor is 0.5 watt 1% except white one
Thanks for the reply, I Already use heatsink on it from the start.Originally posted by georgb View Postin addition to the 2N2222 issue, make sure you have a good heat sink on TIP 127
Originally posted by ripsdevala View PostHi everyone,
This thread still have support?, already build a barracuda from sticky thread and some members question, its work but its only detec coin about 5cm, cigarete pack 15cm.
Coil 17cm 23 turn 0.5 wire
Using bf245b as mpf102 and 2n5485 subtitute
Remove Q5
Already test using 100k on R beside Q5 but not helping
Already turn 0v from 5534 pin 6.
Tip127 hot not melting hot
If I use 12v computer power supply 7660 will get hot
Already check any short and clean flux remain
Still waiting for mpf102 and 2n5485 to arrive.
I dont have oscilloscope, only analog multimeter, if anyone can help will be apreciate.
Bad english....
poor sensitivity
Hi everyone,
Remove Q5
Bad english....
i am an administrator of http://md4all.ru I can remove any subforum where i want to in 2 clicks.
but here if anybody ask he will not get any reaction. infamy?
When I joined Geotech, I did not know there was another Barracuda PI thread, thought this was it.
for moderators. this thread has to be removed in the subforum related Barracuda. tia.
Hi ! Becareful !
Take care of the diodes ! You make mistakes !
Top of the picture must be 1n4001 diodes (blaƧk ones)
48 are the cristal \ red ones !
Thank you, I didn't even know there was an entire section directed for to the building of this board.
