BARACUDA-Legend-1
  • lzwillis
    I got the silverdog baracuda kit, so the picture is not what I am looking at. Thank you for the help though.
  • jladre
    Originally posted by lzwillis View Post
    Q5, R25, and R37 are supposed to omitted. My question is where exactly on the board are they "supposed" to go. I've been looking through this entire forum giving myself a headache trying to figure out which component they are. Any help would be greatly appreciated. I've looked over the schematic about 12 times and can't figure it out. I'm good at soldering and wiring, not so much in electronics.
  • Qiaozhi
    Have you looked in the Projects section? -> Baracuda PI
  • lzwillis
  • maikl
    Rom, not the way it works: " higher voltage greater depth" ...
  • Rom_1
    i made a baracuda which perform well,
    i want to have a little extra depth, so want to use a 18v battery, ICL7660 can accept max 12v.
    Can i replace it with an ICL7662, it accept max 20v ?
  • sinclairuser
    if the little cap has 100k written on it its right its actually 1n K100, meaning 1n= 0.001uf(micro farad) K is its class(+/- 10%) and 100 is its voltage rating
    but 100n is 0.1uf which is wrong, silverdog does make mistakes(rarely) so it could be wrong but i would double check all the box caps when this happens it is almost always due to the correct part being on the board having been mixed up.
    the part you need 1n(0.001uf) will have 1n k 100 on it if it has cap codes written on it it will be 102 K 100 (102 is the code for 1n), hope this helps.
    oh your other question dont worry about the bridges, just build it as is, it relates to a delay control but some builders had problems with it, and the simple bridges made the board more stable anyway.
    p.s. dont use that cap if the rest are correct and you got the wrong part discard it and get the correct one 1nk100 or 102k100 or 102 k any component supplier will have small caps that rating.
  • piston9
    Hi all. First thanks for all the help already in here, it's been very helpful! I have 2 questions...
    We purchased a pre-printed board and kit from Silverdog. If you look at the attached image, it will make sense. ( I couldn't attach it - so it is here - http://www.delvinginto.com/wp-conten...1/IMG_0995.jpg)
    On the board marked as '1', it lists 1N. We don't have a 1N, but have a spare 100N leftover. Has something changed (there were no instructions - just components). That is a large difference, but not sure if I should just go out and grab the correct part per the board screen.
    Also, marked '2', on some boards we have looked at, these have been left empty (eg, see youtube here - https://www.youtube.com/watch?v=gTEED-2Z_lM) - yet on others all of these points are bridged (eg, from this board - http://www.geotech1.com/forums/attac...2&d=1397405934). Can someone tell me which is correct, or reasons for choosing one way over the other?
    I think that is all for now. Thanks again all for being so helpful
  • Koala
    good to hear you have it working properly.
    You do have to be careful which version of 7660 you as some only have a maximum voltage of 12v and easily damaged
  • georgb
    fixed it the delay adjustment corrected the gold problem, but while adjusting input voltage I found that the 7660 did not work properly below 11 volts thus causing an unstable -5 volts. I fixed the problem (for now) by unplugging the 7660 and applying -9 volts to pin5 simulating 7660 function. the circuit is now stable and functioning well. silver dime at 10 inches and small gold ring at 4 inches, all other coins, washers,etc at about 12 inches using the 5 inch coil. (22 turns of magnet wire)
  • sinclairuser
    Originally posted by Koala View Post
    Sounds like you delay is too large. I when for maximum depth on a small gold ring.
    If its working find on coins sounds like everything is okay just needs a tweak here and there
    Coil/Damping resistor or just settings
    not seeing gold can be a symptom of the 2n2222 being in the wrong way round, if this is the case dropping voltage to 9v or slightly lower brings back stabillity, but thats not a fix only a test.
    iv'e seen 2n2222's with different pinouts so putting this in wrong is common in this thread.
  • Koala
    Originally posted by georgb View Post
    Question, help? I just found a flaw in this detector that I cannot explain. the detector works fine at good depths with rings, coins etc. (not gold) but will not detect a gold ring even a 2-3 inches. anyone know why? do PI detectors not perform well on gold?
  • georgb
  • georgb
    I just kept adjusting the offset first and then the delay using small increments at a time. I did it by ear rather than by scope while sweeping the coin back and forth.
    I did get the larger 9 inch coil to work now too. (I discovered that I was not successful at first because there was too much metal around the shop that interfered with testing)
  • Koala
    just got 12 inch sensitivity on coins with 5 inch coil Anyone have any idea of what is the best wire to run from detector (ckt. board) to coil? (twisted pair, coax or balanced line, etc.)
    How did you get such a large increase in depth. Adjustment ?? Coil ??
