The gain was reduced from 1000 to 100 times.
BARACUDA-Legend-1
Try this Q1=TIP127. Q2=PN2222. Q4 and Q5- BF245C. Q3:BF256. Q6=Bc517.This is mi configuration.
[QUOTE=Wilson;177961]Mohandes, I would like to find issues to help you, unfortunately I do not know what else to do, I hope that some friend of the forum to analyze the entire content displayed here and can see the problem to help you.
Good luck: Good
thanks man you are realy the good friend and you are in my heart.
and the final information:
my speaker is 32ohm(and 8ohm too)
complete name of 7660 :7660scpaz
Fabian thanks it is ok , i was wrong in wrote .
and final idea , maybe the equivalent transistor dont work well.except bf256 that instead of 2n5485 ,i change all to bf245c(instead of the mpf102),Nice????
Good luck: Good
Desfazer edições
Alpha
Mohandes, the image with capacitor C16 470nF this wrong, I could not remove after editing.
Mohandes Hello, I'm sorry, the forum has different schemes using or not the fet with SW1. I consulted the scheme that does not have this fet but your PCB uses the Q5, I asked to remove the previous post. In the picture below I explained correct.
The pictures I posted # 976 I missed in naming Q5, Q7 is correct.
mohandes
Original coli inductance 453 uH and resistance R=1,4 and nice to work with other coils... for example 350uH and R=2... which means Barracuda is very tolerant regarding coils.
It is also very tolerant detector as for other electronic components (provided that the correct)... here are some replacement working well: Q1=IRF9640, Q3=Q4=Q5=Q7=BF256, U4=LM358...
My only advice is to play a game with the damping resistor and change of speaker, if that does not work then it's your maximum!
I see you've started and other detectors that are a lot more complicated than this, I think it is for you to "mission impossible"...
