Hello to all, can someone provide me the scheme in electronic format EAGUE program?
Thank you.: Thumb:
BARACUDA-Legend-1
Had the Jim Pugh (Anchor Electronics Barracuda) was a Serb such errors would not be... because the spelling rule is "write as you speak and read as it is written" and "one letter one sound"...means it would be easy "Barakuda".
Best regards.
Most places in US pronounce the first syllable of barracuda like "BEAR" as in "grizzly bear".Originally posted by maikl View PostIt seems that the error in the "label"... everywhere says Barracuda, only on the label of a box detectors, writes Baracuda (any I have ever seen on the internet)...
Does the English pronunciation pronounced "two R" - BaRRacuda?
People from the deep south (Alabama, Mississippi, etc.) they might say "BAR" as in, " Let's go git sum dranks at the bar".
Or they might say "'cuda", or maybe say "bar'cuda".
It is way too late for me to have written anything. Seriously.
It seems that the error in the "label"... everywhere says Barracuda, only on the label of a box detectors, writes Baracuda (any I have ever seen on the internet)...Originally posted by porkluvr View PostSomebody posted a photo of an Anchor Baracuda PI detector, with Baracuda clearly spelled thusly. Strange, because I have seen a picture of the cover of an owners manual that clearly spells out "Barracuda". You can take your pick.
Maybe the Baracuda was a forgery... or maybe it was a labeling error.
Thanks smity nice board, should be easy to etch as well!.
Did you miss-spell barracuda on purpose? if you did nice joke.
hello mohanes
easy print the layout and see at printout if ic socket or ic fit onto holes
also check caps most 5mm spacing
if printout is not right sizes scale printout via printer control
thanks man ok i will Attention to equivalents pins.length is 9.4cm but what size of Width?Originally posted by ApBerg View PostHello Mohandes,
. [ATTACH]24580[/ATTACH][ATTACH]24581[/ATTACH]
think this are the JPG's that are for the baracuda as in the forum, the pcb is copper outsides 94 mm (..I made to many different layouts) so check things before you start ! The circuit diagrams are at the start from this baracuda topic, made by Alex
. Before you start look at them to see what parts you have in Iran or what replacement you can get and collect the needed data sheets from WWW to see the pin-connections.
Succes
thanks
Hello Mohandes,
Succes
Originally posted by Davor View PostHere is a pdf of a baracuda layout for my friend Mohandes
HI my best friend Davor
just my question is very simple your pdf is original and exactly value for the size if i print it?
because this i want Print pcb and make it
and please check #598,are the parts good Equivalent for original parts or i can use combinatorial parts of this number and original parts because maybe some parts dont exist and i have to use the equvalent parts.
thanks
