The ZP uses 3 samples an early X sample and then 2 samples A and B to resolve targets ( and cancel Earth Field ) ..... it can also sample a fourth variable ... the control loop voltage from the X samples.
The VRM ground is occupying the half volume space of the coil field ... the X sample is drives a negative feedback loop that tracks fairly much the field losses and keeps the coil optimally damped.
The A B samples pick up the remaining target .... for long responses the A and B pick up proportionally the same value.
