Hdphilip, I hear what you are saying but the bumps I took to be Moodz' explanation that he has let it ring a little. However if that is the feature needed to be measured then at 500KHz fundamental sampling need be better than 1MSPS if sampling before demod.
Not to take away from Moodz' amazing achievements to terminate and shape flyback leaving essentially an open circuit coil without a resistive damped signal (which I am sure will revolutionise detectors because they do work already and it should make them work better), but I've read a lot of theory that says its there somewhere. That the time constant for non ferrous materials is short so they decay and show up just after flyback (provided its gotten to quickly enough and current is terminated fast enough) but I am still looking. If we could get flyback down to 2uS or 1uS would it show up? Can anyone point out that magic target signal in terms other than as longer/ shorter flyback less/more energy?
By the way I found this little reef known as "Lasseter's" not too far from my house http://en.wikipedia.org/wiki/Lasseter's_Reef . I'll share its location if someone can show me the magic eddy current blip
If we don't know the signal we are searching for, it is a solution that needs no detector.With hdphilip replied, Aziz? Moodz? Carl? Other gurus? Anyone? Can you help? Can anyone post that trace showing a discrete post flyback signal for us to hunt?
Chudster
