Admiral should be very tolerant of different RX coils. Smaller inductance means fewer turns which will reduce target sensitivity but it also reduces ground & EMI signals so SNR doesn't change much. You can restore sensitivity by increasing the preamp gain.
Wanted "ADMIRAL"
Thanks for the answers. I ask because I'm making a new one. bigger coil
DD 33 cm for the Admiral and I want to get it right. Today I wound the windings Tx 1mH R-2.8 ohms, 0.47mm & Rx 11.2mH R-38 ohms 0.23mm.I'm worried that the resistance of the Rx is 38 ohms.
At first look the device works properly, the frequency changed from 8.4kH to 8kH and the volts of the Tx went from 18v to 20v.
Do you think i need to reduce the windings of the Rx to lower the resistance and the induction respectively or leave it like that? Rx-132 windings.
I'm not familiar with the Admiral project so I don't know what the intentions were. bonchev2 says TX=1mH & RX=12mH (post 205) which gives a TX frequency of 8500 Hz. In reality, you can use other inductances and adjust the circuit to work at whatever frequency you want. If you haven't done so, read through this entire thread and see what people have done.
thank you so much
Originally posted by Carl-NC View PostI'm not familiar with the Admiral project so I don't know what the intentions were. bonchev2 says TX=1mH & RX=12mH (post 205) which gives a TX frequency of 8500 Hz. In reality, you can use other inductances and adjust the circuit to work at whatever frequency you want. If you haven't done so, read through this entire thread and see what people have done.
Do you fixed this problem ?Originally posted by bonchev2 View PostThe device works well for coins but does not detect large non-ferrous metals. When I passed with the big object, a strong signal is indicated on tl072 pin 7 but there is no sound indication at all. Has anyone had a similar problem and if so can it be fixed?
