TGSL - EDU , new boards and kits
  • #76
    Hello, where can i find schematic and PCB for TGSL EDU? Thank you in advance!!
    Juka
    • #77
      Juka
      That should get you started.
      Jerry
      • #78
        Originally posted by Jerry View Post
        Thank you for that, but i already have that, and i made TGSL 3.0, but i need TGSL EDU PCB AND schematic !
        • #79
          Hi!
          I dont find it: the connecting the Minelab coil PCB to TGSL! Somebody can post it?
          The TGSL act with Minelab Coil PCB and with 2 tonnes PCB together?
          Thank you!
          • #80
            I am not sure if you find it while searching the TGSL threads. Try looking at the original IGSL thread. Early on Ivconic tried the Musketeer coil and found that it works well. So there is an updated oscillator schematic there that will work. Since IGSL is pretty much two TGSL's on one board, pretty much everything from one applies to the other.
            Jerry
            • #82
              Thank you Silverdog the answer, thankyou Silvedog the TGSL kit!
              • #83
                Jerry
                Hi Jerry!
                I buyed from silverdog a TGSL-EDU kit, and a TGSL-EDU 2 Tone pcb, and a TGSL-EDU Minelab Coil pcb. Than I think it's works with Minelab coil (<~5 kHz). But I don't know: can I use to create so that both functions works (2 tones with Minelab coil)?!
                Either one or the other does it work?
                THX
                • #84
                  dear friend Andy Thank you for amazing quality sets. respectful Andrew Ukraine. the results of my work http://youtu.be/FVY5vKBEnF4
                  • #85
                    I try to connect the IDX VDI to the TGSL edu.
                    But I'm not sure where to connect. Is it the pin 1 & 7 of the U103 or are it both pin 6 of U104 & U105.
                    Or maybe none of these. I tried them all but I can't get any reasonable numbers on the VDI.
                    Every sweep gives a different value. Can someone explain to me what the right way is. Or is it just impossible fir the TGSL?
                    Thanks in advance.
                    • #86
                      i have buy TGSL Kit from silverdog but still not arrive
                      i think 3 week i wait that kit until now
                      • #87
                        hello
                        my name is jerome and my pseudo jerbox
                        i have buy a kit tgsl edu silverdog and i have a question what the voltage (battery type) for work with the tgsl ?
                        9v 12v
                        thanks for your reponses
                        jerbox
                        • #88
                          Hi
                          12V
                          • #89
                            thanks
                            i have already a tesoro spider cortes coil i can use this for tgsl
                            jerbox
                            • #90
                              Originally posted by jerbox View Post
                              thanks
                              jerbox
                              If its got a 4 pin plug on it your ok, got a chart here somewhere with all the Tesoro coils specs on it but cant find it for the life of me.
