Hi Aziz,
Of course I cant substitute 16 turns of 10 strand for 160 turns of 1 strand!!!! A bit of brain fade was going on there I think!!!!! LOL
Now using extra strands in parallel should help reduce the inductance and increase the resonant frequency of the coil which we want to match the tx coil or make the rx coils even faster.
When I was doing my AI mono coil trial setup, perhaps there was a mismatch in resonant frequency(AI Rx coil too slow) between the 2 coils, thus the frequency's being picked up were not matched. With my preamps I can select whether they add or subtract, so the phase orientation was not so important. The other problem I was having was that the tx coil was seeing the RX coil after turn off and in turn causing oscillations as if the coils were under damped and when the damping was adjusted so as not to oscillate, there was a long decay curve noted on the tx coil. So the coil setup was no longer as fast at it originally was with just the mono coil. I did have a damping resistor(variable) on the rx coil. I think from memory when I made 2 identical receive coils and tested them without a TX there was a significant reduction in noise, however it was not as quiet as a DD coil set in cancel mode, but I don't remember what the turns count of the rx coils were or the inductance, but I think it was somewhere around 500~600uH. Will have to make some new RX coils and try it all again!
Ribbon cable would be good to make coils from as all of the strands are tin coated for 1 and the wires are all evenly spaced. What about the spot where you join all of the strands with solder? The solder beads would have to be very minimal otherwise they will support eddy currents in to the receive period. How many strands wide cable do you use?
Merry Christmas to you all!
Cheers Mick
Cheers Mick
I hope the answers above are what you needed!
