Originally posted by baum7154
Best Measurement for Graphite Shielding?
The toughest AL can target I use is 1/4" square and it is detected with CHANCE PI with 8" dia. coil at about three inches.
[A 0.47 gram nugget (7.25 grains) can be emulated with a 9mm x 9mm aluminium square from the side wall of a Cola can.
Originally posted by 6666 View PostThanks guys, have taken note of this, just did a quick test on untuned but working MPP with 6 inch test coil, and the 10mm 3/8 sq piece was no go, but 15mm 5/8 was good for about 50mm - 2 inches .
Do you know how fast you are sampling with the MPP? Just ran the delay to find the threshold where the targets just begin to trigger my CHANCE PI for the 1/4 X 1/4" target and the 3/8" square target. The 1/4" square just appears flush with the coil face at a sample delay of 13.4us and the 3/8" target just appears at a sample delay of 18.8us. Note this test was run with the spider wound bigfoot coil just wound on Friday. At a sample delay of 8us this coil sees the 3/8" square Al target at 5" distance. Any way I think those are the delay thresholds necessary to begin to see these targets, at least on the CHANCE PI.
Cheers,
Dan
Cheers,
Dan
Was looking at some of the charts I posted in the past to see if I could learn something. Comparing the 2 x 2 inch gold simulation and the 1 x 1 inch gold simulation, with no folds ,2 folds and 4 folds the time constant doubled with 4 times the area or volume. The 2x(x) chart the time constant doubled with 2 times the area. The length stayed the same where the length and width both changed in the above comparison. The 2 x 1.25 in foil_6,5,4,3,2,1 chart the time constant stayed the same, total area changed. Each section though connected stayed the same.
Intuitively the result in the '654321' test makes sense to me since the strips were all consistently slotted causing discreet areas for eddy current boundaries and the removal of successive strips made no difference.
The anomaly you point out in the 2xx chart points out the thickness effect but also the elongation effect that we have discussed in this forum before. As I recall there was an example of a 38% difference in the tc when the target was allowed to be elongated compared to keeping it square. I think the targets in that case were cut from pop can.
Dan
Originally posted by baum7154 View PostIntuitively the result in the '654321' test makes sense to me since the strips were all consistently slotted causing discreet areas for eddy current boundaries and the removal of successive strips made no difference.
DanAttached Files
I agree. I think aluminum can is a very good and readily available material worldwide that is easily fabricated but I also think it is a bit thinner than a typical 5 grain gold nugget. That is partly why I tried to figure the volumetric approach between Al and Au. It is entirely possible if not probable that a 5 grain nugget is 3 or 4 times thicker than Al can material. If that proves out to be true then Al can material could be folded to get closer to the thickness requirement and the weight of the piece could be correlated to the gold equivalent from the 7.12:1 ratio of SG Au to SG of Al.
Dan
Intuitively, a multi layer target behaves like a multi layer iron core from a transformer. The eddy currents are mostly confined to each layer.
However, the eddy currents of each layer have their own magnetic field and the magnetic fields add up somewhat like the multi turns of a coil. It is actually the influence of these fields, within the coil field, within the Earth's field that we measure.
An interesting test target is a sphere of lead, or rather several identical spheres of lead like fishing lead sinkers, that can be hammered into different thickness. This way we can easily observe the difference in response of targets of the same mass, but different shape.
Looking at the different response of these targets, gives insight into the effect of the target area presented to the coil field x the diameter of the coil.
Another interesting effect is to look at the response caused by the skin effect that becomes specially significant when the targets are very thin.
