change the wires tx <>rx. there is used differencial inputs of preopamp. so middle/general point ground related to RX winding.
messed up my Tesoro coil (concentric)
No, proposed Wide-scan is DD design with (to ground) center tapped TX coil. Improper to same wiring in CC design. For CC design you wire according bottom drawing in your post #10. Main TX coil and bucking coil can be replaced by its position too, but you need to let possibilities to reverse bucking coil connection wires (if needed).Originally posted by Koala View PostTXb is all ready connected to ground on the Bandido. Would connecting the centre of the TX to ground also short out the bucking coil ???? I am probably missing something obvious.
Originally posted by kt315 View Post[ATTACH]34207[/ATTACH][ATTACH]34208[/ATTACH]
Sehnal jsem továrnà cÃvku S.E.F. 5 pin pro Tesoro, má asi zapojenà jak je na obrázku, na 10 kHz má posuv 40°, 12kHz - 50°, 15kHz - 75°(přibližné hodnoty), do 90° jsem pak měnil C12, v DISC. a dosahu žÃ¡dný velký rozdÃl. Zapojil jsem pin 3,4 na RX, 1,2 na TX. PotÞ je v nastavenà GB, dost ovlivňuje nastavenà DISC.
can you send me bottom side pics of board? my email [email protected]
i need in high resolution pics.
Can't do hi res at the moment is all boxed upOriginally posted by kt315 View Postcan you send me bottom side pics of board? my email [email protected]
The board details are in the Bambino SMT thread including the board files
i get Invalid User specified. If you followed a valid link, please notify the administrator
who is Bambino?
drawed by Foma
