opamp comparator tester
  • #46
    • #47
      • #48
        • #49
          https://www.youtube.com/watch?v=EthhmXL7R8k
          LF357+LF357+TL082
          • #50
            TL084 and LM393
            https://www.youtube.com/watch?v=aror...ature=youtu.be
            • #51
              • #52
                • #53
                  • #54
                    LM393 and LM339 https://www.youtube.com/watch?v=jL9L...ature=youtu.be
                    • #55
                      [ATTACH]43221[/ATTACH]
                      This is strange, I right clicked and saved this gif but when I view it all I see is a black square
                      • #56
                        Yes, strange.
                        Try jpeg.
                        • #57
                          i save a file like 'print' format in XPS. then i go in this site to convert in GIF https://convertio.co/ru/xps-gif/
                          for me the GIF is white and black and open it in right form.
                          • #58
                            schematic is same just i increased a current through the LEDs to approx 10mA (with +-15V supply). i looked datasheets of opamps, noted limited output op-amp current is 30mA but sometimes there are not data. so 10mA is right and no run out of the max 30mA. with +-9V supply the LEDs current will be yet low.
                            batch of LF357 i checked and they are OK (good way - you can check a couple at once LOL). would check them in DP now.
                            • #59
                              SCH file
                              • #60
                                this opamp tester i did much years ago. in 86 or 87 i do not remember. it was good time of Spectrum ZX80 personal computer
                                we made. certainly the spekky was not original, it was Zonov's schematic. i tested some opamps before to solder in the board.
                                http://ipic.su/img/img7/fs/P1090305.1528140998.jpg
