chance pi build
  • #91
    Good Job!
    Unfortunately it is not to easy to find a computer with serial port now.
    So using USB programmers looks more convenient.
    Take a look what you can have for $3.
    • #92
      silverdollar, sometimes between different computers you can have problems with the 3v in the paralell port, there is a workaroud where you isolate the voltage from the computer and provide the voltage separately to the programmer, though i have not done this, i switched to serial and then usb ages ago.
      i think the separate power helps when using different machines, as some pc's have no power pin or different pins for power, there are those who prefer paralell programing, another thing to check is port mode in the pc's bios(sounds obvious but can be forgotten).
      • #93
        Here's the schematic to the parallel port programmer;
        The buffer chip runs off the power in the board to be programmed so the problem
        is the MISO signal that is buffered on pin 9 of the chip is a CMOS signal at the voltage of
        the board to be programmed. Normally pin 9 goes to pin10 on the connector through a resistor
        so I made up the level translator using a transistor, the problem is I have to get 5V somewhere
        to make the computer happy. I'm not sure if the programming software keeps any lines high
        that I can use.
        They had trouble with USB programmers at work so have standardized the parallel port type.
        I saw those USB ones and figured they are just a serial emulator but wasn't sure what software to use
        with it. I also have a low budget so free is better than even $3...
        • #94
          I have used USB programmer for AVR. You can find it on eBay starting $3. Name is USBASP. http://www.ebay.com/sch/i.html?_nkw=USBASP
          Also there is a very simple software to use with it - Khazma AVR programmer. http://khazama.com/project/programmer/
          But please pay attention for fuses because for Khazma checked bits = 1 but on Chance website with Ponyprog screenshot it has checked bits = 0
          So INVERT ALL FUSE BITS or Ooooopppssss.... Atmega8 Bricked.....
          Also write codes first than fuses so if you mess up with fuses you will have at least codes ready to go.
          Usbasp works well with eXtreme Burner-AVR software. Find it here : http://www.fischl.de/usbasp/ . Works fine on Win7. Used it for programming open source stuff on a Turnigy 9x. Also reprogramming my generic Lipo charger. Theres an online fusebit calculator here : http://www.engbedded.com/fusecalc/ . Where you can double check before programming. Important for a nub like me.
          • #95
            Also if you like to save $3 you can build your own USB programmer for your AVR microcontrollers using cheap 8 pin Attiny 45 or 85: http://www.simpleavr.com/avr/vusbtiny
            • #96
              I use the same as Silver Dollar and is perfect. It costs nothing and works super !
              • #97
                If your computer in new probably you will see no serial port in it so you need to buy or build USB programmer.
                For older computers with serial port "3 RESISTORS" AVR programmer keeps a record of cheapest of the cheapest : http://www.electroons.com/electroons/programmers.html
                • #98
                  Who can tell how Chance identifying ferric targets?
                  What sound tone you have on iron pieces with your properly adjusted Chance?
                  With different coil inductance I can see some changes in target identification:
                  coil inductance --- 400 uH --- 300 uH
                  cooper coins --- high tone --- high tone
                  Au,Al,Ni --- middle tone --- middle tone
                  Ferric targets --- middle tone --- music box sound
                  Because no instructions I have no idea what that music "cannery bell" sound has to indicate? Is this Iron ID? Can you confirm?
                  If so, that is good because I want to get rid of iron trash. And lower inductance coil may help to adjust identification.
                  400 uH coil works bad because gold and iron sound is same.
                  Those modes of iron rejection 2,3 reducing not only iron but gold rings signals too.
                  I have tried different coils. Inductance makes a difference in target IDs.
                  Any shape can be used and for "slow" high capacitance coils guard interval has to be increased but sure platinum and some gold goes undetected if so.
                  I have no idea is my Chance works right or wrong. That is only what I can see.
                  • #99
                    I'll try to answer your question the best I can. With my 8" 335uh spider coil and the Guard Interval set to 10, a 12 penny iron nail pointing directly at the coil gives a high pitched tone much like the response to silver. The same nail presented broadside to the coil gives a low tone at greatest detection distance and as the nail gets closer and the signal strength gets stronger, discrimination kicks in and the melodious high pitched tones begin. The right hand end of the VDI is correlated to the high tones and this includes copper, silver, and iron. The left end of the VDI is where the low tone is allocated and this is where gold, aluminum and nickel reside. Saturation of the Signal Strength level gives a raspy buzz.
                    I also tried different Guard Intervals to see what effect they had on audio response. The same nail target was used.
                    GUARD INTERVAL-----END ON TO COIL---------------------------------------BROADSIDE TO COIL
                    12-----------------------8" low tone, 7" musical, 5" solid high tone------------8" low tone, 4" musical notes begin
                    15-----------------------8" low tone, 6.5" musical, 5" solid high tone----------8" low tone, 3.5" musical
                    20-----------------------8" low tone, 6.5" musical, 5" solid high tone----------7" low tone, 3" musical
                    30-----------------------8" low tone, 6.5" musical, 5" solid high tone----------6" low tone, 2.5" musical
                    So to answer your question both very high pitch and musical audio can represent Iron depending upon target shape and orientation to the coil. It is interesting that there is a musical transition from solid low tone, to musical, to solid high pitch tone when the target is presented 'End On' to the coil.
                    I hope this helps.
                    Dan
                    • Originally posted by baum7154 View Post
                      I hope this helps.
                      Dan
                      CORRECTION
                      The nail used in the above test was an 8D, NOT a 12 penny nail. Sorry for the confusion.
                      Dan
                      • Thank you! Now I have a data for comparison.
                        For my tests with longer delay (Guard Interval) results are more stable.
                        Looks like my Chance works properly because it shows similar behavior.
                        Also I see Chance is not a "motion detector". I have a habit to swing target near coil after years of use of Surf PI.
                        With Chance you can just keep a target near coil and get the tone. Shaking target makes things only worse.
                        That tone you call "low" is the same tone you have for gold ring? Because in my case I have a low tone for gold rings is same as for iron nails.
                        For very big iron targets (screw-bolt) I have a "very low" tone sometimes. May be it is iron signal or overload signal. Too bad author has left no notes.
                        • Yes I was wondering why you were trying to move your coil in water at 5ft/sec with CHANCE PI in your discussion on hydrodynamic drag.
                          Yes the low tone is the same as for a gold ring or small piece of aluminum. The low tone for iron nails happens for me too at low signal levels but as the signal level increases the discrimination becomes more defined and the melody tones begin for copper, silver, and iron at the right end of the VDI scale.
                          The very low tone you see with large Iron targets is raspy and lower than the low tone for gold and aluminum. That very low tone indicates signal strength is saturated or overloaded.
                          Dan
                            Because of size of the area.
                            After government replenished sand on the beach and then sand has been washed back to the ocean
                            submerged sandy area has increased three times over that you can see on this picture: Click image for larger version
                            It was huge. Now it is endless. Also number of tourists has decreased several times.
                            So now I am walking over several football fields finding only few targets. With speed 1ft/sec I will find one penny a day. I wish I cal fly.
                            One Italian guy has searched that area with Whites Dualfiend for 90 days day by day to find only three silver rings this winter.
                            Problem was that he can only push that bulky coil forward, he can not swing it in water because of huge drag. As result 0.05% of area has been searched.
                            I remember the time when real gold rush was here. Now I am practically go outside for exercising and listening music with MP3 player installed into my Surf PI waterproof box.
                            Some good stuff probably remains in corals but I need a target id machine (Chance?) to dig from corals only good targets.
                            • Beautiful picture of Waikiki and Diamond Head. I miss snorkeling at Hanauma Bay!, but not the Lion fish I met there!
                              • Did a bit more scope time in the CHANCE PI with an 8" fast spider coil today. Measured the time it takes for the OP37 to come out of saturation on the flyback signal at various gain settings. The coil itself measured at the protection diodes decays in 6us. With the designed gain of 470 the OP37 amp takes right at 16us to come out of saturation and smoothly back to zero with proper damping. Dropping the gain to 43 the amp settles to zero in 8us. Further dropping the gain to 21 allows the amp to settle to zero in about 6us, virtually the same as the coil itself. I took pictures of these test measurements for future reference.
                                I intend to build a 2 stage op amp, 1st stage inverting with a gain of 20 to 25, and the 2nd stage non-inverting with a gain of 20 to 25 to allow better/faster sampling for small gold targets. Has anyone built a similar two stage op-amp using two of the OP37 chips and a nominal +12V & -12V supply? No sense re-inventing a good wheel!
                                I appreciate any responses.
                                Dan
