  • Originally posted by basellafe View Post
    change ic357
    do you suspect it's shoddy?
    Thanks for the advice!
    • maybe its a fake but you should give a try
      • YES, I'll do it.
        Thanks!
        • What if i use 0.5 watt 390 ohm 1% resistor for the damping ,is there will any problem? Cant find 1% for higher watt.
          • felezjoo pi - part list.pdf Pay attention on marked part.GOOD LUCK!
            • Originally posted by ripsdevala View Post
              You can build the resistor buy parallel and series resistors to get the needed wattage
              • i need hex files but it shouldn't counter. if you have hex files can u send me ?
                  Good idea, never flash in my mind . Thanks
                    Some of the 1/4 and 1/2 watt resistors have a 250 volt working voltage. Would it be a good idea to series 2 or 3 resistors to get the correct ohms and watts when the peak voltage is over 250 volts or is the high voltage spike so short that it doesn't matter?
                    • Felezjoo v3_05 hex code error ...Do you have a running v3_05 hex
                      • best hex kodu version ?
                        • 100 ohm resistor to connect 180 ohm series
                            Yes its always a good idea to run components within specs so with a typical PI flyback voltage of about ~400 volts 2 or more in series will over come the break down problem,
                            I find that excessive heat kills resistors , at least with my projects, so building for power so they don't run too hot is also important .
                            • Hi fellows. You could teach how to program atmega with arduino.Thanks
                              • Hi
                                download this ;
