    Schematic has been completed, but just need to check it over before posting.
    Cannot do it now, as I need some sleep.
      Hey guys
      I have prepared a PDF for you, which is a description of the system and its performance.
      I hope to be useful.
        Explanation of some questions
        In response to common questions such as whether the detector is sensitive to salt or clay? Or how is sensitivity to the gold? Or how does this work by a big loop? Or even what kind of loop in this circuit there?
        I must say, basically the questions about this particular design is almost meaningless!
        As already mentioned with regard to all possible options, virtually no special factors in the common pulse detector and not be changed by digital setting device.
        Note that the sum of the settings of the device if you wanted to be an analog circuit requires at least 10 volume and perhaps as many more IC, and in no time, as well as digital system did not work!
        But in this project, in fact, with any digital set of simple settings, we have a new metal detector, which will feature different.
        With a range of settings, sensitivity to salt is extremely low.
        And other settings, is much more sensitive to gold.
        As well as the maximum sensitivity to metal, or the depth of the soil, all with the settings are changed.
        So the plan is completely flexible, a perfect alternative for the thousands of design, which is a special feature.
        And provided that, depending on the needs and tastes of the operator can get the desired response.
        tnx
          Originally posted by koohyar View Post
          Hey guys
          Excellent work koohyar.
          Thanks to deal with us.
            Just ordered a ATmega328P-PU for this project a schematic would be usefull.
            As promised, here's the schematic. If you spot any errors, please let me know and I will correct them.
            I've also included a PCB overlay with the components and tracks combined.
            I guess we'll soon know how well the "iron reject" feature functions, and whether it's capable of working with Oz soil conditions.
            It would be interesting to test the claimed ability to detect small gold, as the huge gain in the preamp should be a barrier to sub-10us sampling.
              Hey guys
              Thanks kooyhar.
                HI Qiaozhi,
                With gain like that on the preamp, I can tell you it definitely will not work here in Oz..
                Cheers Mick
                  Originally posted by Mechanic View Post
                  HI Qiaozhi,
                  Cheers Mick
                  That was exactly my thought as well, but the claim is that this is a PI detector to suit all conditions, and with iron reject.
                  We shall see what we shall see, as soon as 6666 has built a copy for testing.
                    From the pictures I posted at the link below, everyone can see how bad mineralized soil is and thats only with a preamp of 100x.
                      well done
                      but designer tell in Iranian forum can set TX power to 400mks.and about PPS too can adjust.
                      but the important part is reject iron.
                        Originally posted by mohandes View Post
                        well done
                        If you have built this detector, can you please tell us how well it rejects iron? Can it do this for different sizes and different shapes?
                        In your notes its says:
                        "Iron Reject: (iron removal) This setting is similar to the GPX Minelab series , And by a complex formula of iron diagnosis, is done."
                        But ... the Minelab GPX uses Multi Period Sensing (MPS), Dual Voltage Technology (DVT) and Smart Electronic Timing Alignment (SETA) ... and I don't see any of these in the schematic. The GPX is also designed to find sub-gram nuggets, which requires sub-10us sampling. With the preamp gain set to 80dB (and a 380uH mono coil) there is absolutely no possibility of this happening in this design. I'm sure the software is using some novel techniques to try and extract target information from the input signal, but [like all PI detectors] you cannot extract information that's not there. Although you can do some clever manipulation of the sampled data, any so-called "iron rejection" will still be based on target conductivity, so it's never going to be anything more than an educated guess.
                        Of course, I stand to be corrected, and look forward to 6666's findings.
                          one thing is more important and it is your coil. 0.7ohm and 350mkh.for each coil you have 3 number that you can see in the LCD,and you should check it by that.your number should be near of those numbers.if your number ok so you success.
                            Hey guys
                            Thanks for the PDF.
                              THANKS Qiaozhi, much appreciated, this will be a long term project, and depends if I can manufacture the pcb.
                              I would like to discuss R5 which is 2.2k , I've seen similar ccts, with the resister being as high as 10K such as the Skif PI
                              what concerns me a bit is that circuit configuration will dump the 12v onto the gate of the IRF840
                              but wont the high value of resistance 2.2k (up to 10K) limit the current into the gate and not fully turn
                              the fet on ?
                                thx koohyar for the info and some 60cm-70cm coil always is super and should became standard for deep-search!
                                Of course someone can (and in this case: should) use a socket for the chip so its removable and reprogrammable.
                                (don't set the write-protected fuse to on)
                                And if the gold-containing Aussie-soil really is such ultra heavy mineralized I would use
                                a non-motion VLF detector with very small coil to get good discrimination for the small nuggets -
                                at least at areas full of iron junk.
                                btw. seems there runs not everything perfect at this iranian forum:
                                this here was posted at our LRL-forum:
                                Discussions on LRLs of the electronic variety which also utilize L-rods or other swiveling methods.
                                subject:
                                felezhoo.com
                                04-19-2015
                                hi dear friends
                                i want to talk about an iranian forums "www.felezjoo.com"
                                is someone that know about this forums adminstrators? because i heard they are very dishonest and deceitful. their names are .hamid (حمید) and mojtaba (مجتبی)
                                They sell a treasure finder fpl-35 called for people who have bought it are very unhappy.
