  • MartinB
    Did you leave an air gap in the shielding? Did you connect the shielding to ground?
  • manos
    Originally posted by manos View Post
    Hi i made two of this metal detector felezjoo pi from the #1 post, i have the same problem work ok with metals but when i start with the disk 30cm spider coil 380 mH 1ohm
    in the ground filter i put 1 to 3, then i press down, when i start walk it start ring i press again down and stop when i do a few steps start again i keep the disk about in 10 or 30 cm of the ground but allways ring with the 3 numbers of coil 302 700 789 . Any help for this problem ? Thanks.
    Any Help for this please.
  • manos
    yes i have shield the coil with the N-77 GRAPHITE SPRAY​ ,but they ring and before with out shield, no i dont have photo and ring with any coil i made
  • Emersonpaz
    Did you shield the coil? Do you have any pictures of your plate and coil?
  • manos
  • manos
    Hi do you have the felezjoo target id list (number and metal )
    like this but for felezjo. :
  • manos
    Originally posted by ionut_mtb View Post
    Try to reprogram again the atmega 328. Verify connections to display and power supply for display. If i remember correctly first start after programming you need to push ok button when you see letters, if not, will disappear, too much/less contrast.
    thanks, i fixit the connections in display one pin have not good contact
  • MartinB
    Some nice ideas there.
  • ivconic
  • ionut_mtb
    Any help for this ?
  • manos
    Hi i made felezjoo and i don't have letters on screen, when i power on i have sound and in off, were i should look for it, i post some photos , thanks.
    Any help for this ?
  • manos
    I check the green spot and the red is ok but still not work the lcd
  • Emersonpaz
    It is visible that there may be a short or dot in red or broken track in green check.
  • manos
    felezjoo photo thanks if can help me
  • manos
