  • Qiaozhi
    Originally posted by marin2 View Post
    How do you calculate coil?
    Coil Calculator
  • marin2
    With lm318 i always had
    500 840 840
  • cvele
    No, it cannot be!
    May be 320 350 390. In that case lf357 is fake.
  • marin2
    to Cvele
    debug numbers
    A 32 B 35 C 39
  • cvele
    to marin2
    there are a lot of coil calculators online, just go to google and try (coil calculator), I am a little bit confused with Your debug numbers.
    What are they exactly? a=? b=? c=? (300, 700, 800 - optimum)
  • marin2
    thank you very much cvele
    I have decreased to 24 turns
    But it's always better 37 37 45
    Detection coin of diameter 3 cm to 14 cm
  • cvele
    Hi marin2
    inductance of Your coil is too high 591uH, Try with 25 turns and if not good enough, go to 24, lf357 looks ok but do not use holders for transistor, just solder it directly on PCB.
    A little bit more about coil - try some other tips (basket or spider), there are a lot of examples on geo.
    regard
  • marin2
    Here the coil 27 round diameter 28 cm
    Wire diameter 0.7 mm
    And voila 357 is it original ????
ID:	349085Click image for larger version
ID:	349084Click image for larger version
  • karim1980
    ici 357 is not original
  • lc516
    Hello everybody
    I always have low values
    A: Almost B : 30 nearly C : 40 almost 100
    You can show your coil
  • marin2
    Hello everybody
  • smit22
  • cvele
    and:Click image for larger version
ID:	348966Click image for larger version
  • cvele
    Nice work smit22!
    I prefer small (20 to 25cm) coil and use manual set up for delay, usually around 20, and spider kind of, because it is easy for me to set it up.
    Here are some pics of 25cm coil I just made and as You can notice wires are not soldered yet so a)300 b)688 c)784 will come in place after soldering and
    making all rigid.
  • smit22
