  • fiz 3 aparelhos e 3 verc?es..mas nenhum deles serviu aqui...terra vermelha muito mineralizada, deveria ter um balanceador de solo manual
    • I made 3 devices and 3 verc?es..but none of them was able to be used here...very mineralized red earth, it should have a manual soil balancer
      • I tested it in the sand of a soccer field and it worked very well
        • however when I use it on mineralized soil it does not store the soil configuration and every 2 seconds I have to do the soil adjustment
          • melhor aparelho para minha regi?o at? agora foi o tgsl... ganhou o minelab safari e o fisher f5 que eu tinha
            • minha ca?a favorita ? o tgsl at? agora..ele venceu o vanquish e muitos outros..
              • Hello,
                Someone can recommend me a coil configuration (type, inductance, size) for good search (rings, coins) on the beach? Thanks.
                • Originally posted by cristiano.sar View Post
                  Hello,
                  https://www.geotech1.com/forums/show...il-Felezjoo-pi
                  • Thank you!
                    • I finished building the Felezjoo, but it is too slow to start, it takes about 5 minutes to go from the start message to the menu and when it is there, the joystick commands seems very slow to respond, anyone else having this problem? Thanks.
                      • Cristiano.sar
                        Fuse atmega
                        • Thanks for the help!
                          I got it working, after bricking an Atmega, I burnt another with usbasp and avrdude from mac os terminal with the commands below:
                          avrdude -c usbasp -p m328p -u -U flash:w:felezjoo_full_M_3.35_.hex
                          avrdude -c usbasp -p m328p -U lfuse:w:0xf7:m -U hfuse:w:0xd1:m -U efuse:w:0xfc:m
                          Now it's working normally.
                          Video:
                          https://www.youtube.com/shorts/z90xZGA7VOI
                          Special thanks to @Emersonpaz
                          • hi guys.does anyone know where i can buy some pcb and some parts?i would like to try the build!!maybe from some european country..i'm in germany..thanks a lot
                              [ATTACH]58288[/ATTACH]
                              Video:
                              Just sharing the final result:
                              • Originally posted by barbaposa View Post
                                kind regards from brandenburg, i can deliver the most parts
                                pcb
                                coil shells
                                detector stem
