2nd Chance PI
ID:	348535Click image for larger version
Name:	chance 2 PI.jpg
    Please check my assembled version not working
    Last edited by UnHappy; 05-19-2017, 12:09 PM. Reason: time out while attaching pictures
    • Can we have the layout to compare , As I am unable to initialise it
      Originally posted by walkman View Post
      Hello friends
      My best friend mustafa, made chance rev2.
      With his new design pcb.
      I add the pcb pictures he made and the video he shoots.
      Good looking
      https://www.youtube.com/watch?v=AdzgmCRVShM
      • Originally posted by dantech View Post
        At the moment the code is practically rewritten by me, timings are changed and some hardware changes are issued also. Since now my releases
        will be called "2nd ChancePI" to distinguish from base project called "Chance PI"
        I have to point out that every my software release has roots in the project called ChancePI/AndyF.
        Thank you AndyF for you hard work.
        2nd ChancePI v001
        http://chomikuj.pl/dantech/2nd+ChancePI
        Hi Dantech!
        Sorry but I don't understood if do you have written the new code from zero or do you get the source code from AndyF and after you have modified it.
        Please can you explain if is it the first or the second?
        Thank you.
        • You do not have to understand.
          That is clear, enough and true statement
          • I realy dont understand why not sharing the source code for a non comercial DIY project.
            I feel the same about KROT2 and QUASAR. Is it a coïncidence or not, those 3 projets come from Russia !! Strange ?
            The author of PICKINI has shared everything about his project.
            If i make a free software, i'll share to all of you on the forum cause that's the goal of it.
            • Simple answer.
              It works quite well and there is serious risk to abuse rights for commercial purposes.
              Like you know 2nd Chance PI has anti commercial lock implemented.
              There was hundreds hours spend to develop project.
              That is my decision and I shall not change it.
              Everyone can use it for personal purposes but commercial purposes are strictly forbidden.
              If someone has some idea regarding functionality, just write here. If it will has sense I shall try to implement it.
              BTW. 2nd Chance PI comes from Poland but has the deep roots in Russia.
                Make it to be a motion detector like baracuda/pickini plis.
                • Like I said earlier that is not true the pickini or barracuda works as dynamic MD.
                  Both works in the same way as 2nd Chance PI
                  So stop repeat the strange "truths".
                  Here is proof:
                    Simple answer.
                    I apreciate your work a lot and i understand your reasons. Each person think different and i respect that.
                    If i had the code, i'll modify the audio output to feed a vibrator.
                    • There is one serious problem. There is no free pins on ATmega328. The only one which is free is Tx output.
                      I want to use it as a outcoming data to other subsystems, so I cannot implement vibrator support
                      • A good way would be to drive the lcd by I2C with a converter board.
                        Or simply use the same pin to drive the vibrator and the audio with a different driving method through the soft..
                          Here is proof:
                          https://www.youtube.com/watch?v=xILHzZQlFM4
                          I mean when chance sensor near metal object it would not stop beeping, right? Not with Baracudda and pickini, the md only beeping when you move the metal object.
                          Why im asking this?? im already make attemp to make baracuda to be a non motion but the result is always beeping above the ground, and many non motion detector always behave like this, thats why...
                          • Every PI works as static MD.
                            You can try to change in the menu things called "Filter adapt." and "Filter recovery" eg. values 1/1
                            • firmware v023 is released
                              • Do you have any Setting/operating manual for this Chance2 for laymen in MD projects? Also Kindly Tell Which SW1=?,Sw2=?,Sw3=?,Sw4=?, Sw5=? & Sw6=?
                                ?>>>Nomenclature or Names for using to operate this Detector
