Looks great JL.
I like the single board, it makes the project look a bit simpler.
Also like having a connector to bring in all timing signals from the 'digital/control' board.
One thing I seem to see that might be an issue.
The ADC (LT237
ADC_REF cap (C51) needs to be very close to the ADC's ref pin 8 and ground.
We are using this ADC where I work and I found that there is a good current draw when the ADC starts acquisition (charging it's S&H cap).
This caused a huge error on the ADC value.
Also, 100nF is NOT enough C on this pin. Data sheet suggests 47uF, low ESR and we used a 100uF, 1206/1210 size.
Kemet C1210C107M8PACTU - Digikey #399-11631-1-ND
or Samsung CL32A107MPVNNNE - Digikey #1276-3364-1-ND
The ADC (LT237
ADC_REF cap (C51) needs to be very close to the ADC's ref pin 8 and ground.We are using this ADC where I work and I found that there is a good current draw when the ADC starts acquisition (charging it's S&H cap).
