Pulse Star II (first analog version)
  • Originally posted by Ruben2000 View Post
    I hope to make an analog pulse induction detector.
    I have mostly completed my design work on my analog metal detector which is named AGD23-2 but will be updated to AGD23-3 for the final version. The AGD standing for Alaska Gold Detector. The goal of this project was to design an analog detector using modern components as my performance standard to compare later versions that
    • not quite there as yet. but close Click image for larger version
        Hi
        nice work and thank you .
        • I put sprint file for anyone who wants to play with it. The bottom layer is complete and well known. The top layer is almost complete, still missing a few tracks. Errors in the top layout can be corrected along the way. In finalising the layout, all the components need alignment fine tuning(all ducks in a row, so to speak)
          A scheme can be traced from the layout, the last pieces of the puzzle will fall into place.
          The resistors connecting to the sample delay switch are known. Most of the component values on the board I already know.
            Please leave the part list of Pulse Star 2 . Or send to my email​ [email protected]​
              5,4 = Coil
              1,3 = Charger Gnd
              2 = Charger Plus
              ​Click image for larger version Name:	image.png Views:	0 Size:	73.2 KB ID:	411095​
              Can you send me the circuit pulse star ll, thank you
              [email protected]
                5,4 = Coil
                1,3 = Charger Gnd
                2 = Charger Plus
                Can you send me the circuit, thank
                [email protected]
                  Only schematic that i have is from some Turkish forum. Full with mistakes.
                  Luckily i got original pcb boards and i made it respecting those.
                  I intend to draw most proper schematic, relaying on present state at working pcb.
                  But it would be pretty tedious job... i will need some time.
                  As you maybe noticed; i used only "motherboard" so far.
                  Also i plan to populate "discriminator" board too.
                  Other 2 boards (front and rear panel) i don't intend to use.
                  Original charging part (on rear pcb) is obsolete and total overkill.
                  I have much simpler and easier charger on my mind.
                  Front pcb also is not suitable for me; due some components and volumes that i can not obtain.
                  Instead i will draw my own front panel pcb with components that i can obtain here.
                  Only "motherboard" is relevant. And maybe "discriminator", not sure yet, will see soon.
                  Hello Ivconic
                  I know that you promised the north, but I don't want the circuit that you promised. I want photos and schematics from that Turkish site.. The same schematics you said are wrong... That Turkish site no longer exists.. Please send them here or to my email.
                  thank you.
                  my email [email protected] ​
                  • Unfortunately, I don't have them anymore.
                    I deleted them from my drives a long time ago.
                    What I have is what a friend gave me to whom I promised not to post it on the forum or share it with people via email.
                    I'm really sorry, I apologize!
                      Any way ...ok
                      • Comment
                        • I continue to work. Almost done.
                          • Comment
                              Unfinished.
                              [ATTACH]n427260[/ATTACH]
                                Unfinished.
                                THANK YOU SO MUCH CHOKRAN
