Delta Pulse
  • mehdi
    Hi friends
    anyone know how i can increase strobe impulse to 1000 us in delta pulse?
    best regard
  • sevar12
    Yes i see thenk you very much
  • Tepco
    No way to work whit 5534 (or anything similar)
  • sevar12
    hello every one
    now i see that ne5534 not be the same as lm 357 may be this is a problem to dp not work
  • Tepco
    U4 is input amp, U6B acts like integrator, (R19/C16 time constant) auto-zeroing U4 when U9D is closed. U4 (LF 357) is somewhat specific chip, whit common mode range accepting +V, and about 100mV above (can not be replaced whit 5534 or some other typical PI opamp), circuit will work this way. Power supply distribution on XR71 in complete nightmare, but works, no matter how strange it looks, figure out what is GND reference for what part of ckt.
  • DOOLEY
    hello , pics below.
  • DOOLEY
    hello all ,
    been looking at the delta pulse and xr71 schematic , and i'm a little puzzled , hope somone can explain.
    below is two extracted pics from dp / xr71 ,
    firstly , the two op-amp's u4 and u6b , look to be feeding back / in a feed back loop , why is this , what is the purpose , checked on the net and can't find any examples that have this configuration to get an explination of what's going on.
    my first thought was a type of automatic gain adjustment or automatic leveling of signal , the nearest thing i found that looked close was a high pass filter.
    next question , i notice that the first op-amp , u4 has the same feed as the search coil , 12V , how can this work , as far as i was aware , the first op-amp requires a hight supply than the singnal which its dealing with , in this case it's 12.7V ish down to 12V , yet u4 appears to only have a 12V supply , ( +E) same as the search coil.
    and lastly in the power supply pic , u6a , looks to delivering a regulated , but low current 5.3V supply to a reil noted with the ground symbol , been trying to work out a voltage scale for this detector , (-12V) = 0v
    (-E)=1.4v
    earth=5.3v
    (+E)=12v
    can't see anything higher than 12v so still puzzled as to how u4 can work.
    i could be blind , and haven't seen it yet , but this is doing my head in , please help.
    pics on next post , forgot to add.
  • fidamohd82
    hi
    and what do you advise about the coil
    regard
  • homefire
    Originally posted by fidamohd82 View Post
    hi to all
    i made the delta pulse it is working but with no depth just 3 or 4 cm
    what will i do
    If you in fact built by the schematic and used the correct parts, how did you build the coil?
  • fidamohd82
    hi to all
    what will i do
  • boeNorway
    hmm
    whats the price for all the components for the Delta Pulse
    and was there someone here that sold the 2 side pcb if i asked nice
    ore is there some one here ho is ready to bild another metall detector and dont nead
    the Delta Pulse pcb and components
    Sorry for being bad at spelling but im made this way .
    Best Regards to all of you .
    this Thread was werry intresting .
  • raff33
    Originally posted by Jose View Post
    Hello Raff33
    Set the multimeter in frequency counter function
    Punta black on - E, red lead on pin 9 of IC 556.
    It can perform with the coil disconnected.
    Jose
    Hi jose,
    now i inderstand ......
    - black lead on -E(pin7 of LM556).
    - red lead on (pin 9 of LM556).
    many thanks
    REGARDS
  • Jose
    Hello Raff33
    Jose
  • raff33
    please can anyone gide me how to get my delta pulse frequencey with my digital multimeter ?
    - where connect black and red leads ?
    - should i mesure frequency without connecting coil ?
  • Jose
    Thank you for clarifying the concepts kt315.
    Jose
