Delta Pulse
  • Toros
    hi George
    that will be only good but my english is not so perfect to make it.
    i began write some article for russian magazine but it is still not ended. also i have html from one russian Koliaj name
    who was first done DP.
    if who will agree to translate in english i will send him both texts.
    i did pic you could see the Koliaj's text
    thank you for support
    KT 315 why are you giving incomplete information? The correct link is:
    Anyone who can read in Russian can take advantage of the file.
  • star
    delta pulseClick image for larger version
ID:	349413Click image for larger version
ID:	349414Click image for larger version
  • 6666
    answering i say you again. ALL VALUES on the PCB are correct. if you see BOM ok do like bom file.
    if you think 12k you change on 10k you get unworking something that is only your delusion.
    OK you win.
  • kt315
    6666
    you missed my point
    this pic is open for you? what you see there?
    two people emailed me about BOM file. so i did new BOM for them, backing to old values.
    you do not see whole my correspondence. if someone is beginner i give info on zero level too.
  • 6666
    6666,
    no reason to scratch off the resistor value just cause -----
    --- values of XR71 are working
    --- values of DP are working
    --- my values are working.
    i suggest you to begin to learn the f-g electronics... yes, the electronics. if you are newbie you must begin to read the useful books
    not asking me why values same or not same. you are like blind squerell in the midnight hoping values will
    change something, depth or what you imagine yourself... but not... no difference.
    Kt315 you missed my point
    let me try this a different way by asking this question
    Is the schematic in post #3251 AND the BOM in post #3271 100% correct and are they both for the PCB you sell ?
  • kt315
    my article, beginning
  • kt315
    hi George
  • Qiaozhi
    6666,
    cheers
    write more good story. any mention of DP will be greatly appreciated just you do my day.
    Hi Anatolij
    May I suggest that you produce a Delta Pulse Build Document similar to those for the MiniPulse Plus and Geotech Baracuda designs. I can send you the Word document to use as a template.
    It would make your life a lot easier.
    I'm sure we could help you to correct the English if you have a problem.
  • kt315
    your #2
  • kt315
    your table book #1
  • kt315
    6666,
    cheers
  • 6666
    Hi KT315
    Don’t get mad OK ? I am just trying to help you, and I can only write this in English, and is given in good faith.
    I have been trying to work out why some people have been having trouble making your delta pulse and why they ask questions about R39 and R40.
    I have been reading through several threads about your DP.
    The problem seems to be there is different information spread across several threads that do not match,
    the latest schematic see post #3251, and the latest silk screen on your black PCB and your latest bill of material (bom) don’t match.
    You may have published the latest component information somewhere buts its very hard to find it and combine all the information together.
    For some reason only known to you, since you published your latest schematic and pictures of your PCB, you have changed the values in the BOM of R39 and R40, and has caused some confusion
    This problem can be fixed very easy, so people can make your DP and get it working.
    First remove all pictures of your latest PCB from your album etc,
    then scratch off the resistor values of R39 and R40 from the silk screen of your PCB and take new photos ,
    this will make it less confusing.
    Next update the schematic with new values of R39 and R40.
    The updated BOM, schematic and new pictures of PCB with values of R39 and R40 scratched off need to be published together on several threads I can list them if you want.
    cheers
    6666
  • jezz
    I guess that is why you are still explaining the board 132 pages later
  • kt315
    post #3153
  • kt315
    which is right ?????????
    kt315 is always right. THATS MAIN RULE.
