Delta Pulse
  • kt315
    thank you much, Carl and George. i always know that it was just mistake to close this thread.
  • nncu2020
    What is ITMD?
    I attached a picture with the wave forms taken from VD3/VD4 + R6 (1K0). I would like to know if that is what we normally see when the Delta Pulse is working Ok?
  • kt315
    to expect from the circuit --- ITMD was written for beginners. ITMD is perhaps RTFM for breadboarders.
    ok. what you have to see on limiting diodes? the limited 'delta pulse'. good start for understanding what is delta pulse in Delta Pulse.
  • nncu2020
    Thank you kt315
    I remember a TV from Soviet Union (krimp 218 it had a lots of kt315G :-)
    Thank you KT315!
    Here is my first attached image:
    I am beginning to make a Deltapulse. I have use a breadboard to test the driver circuit (timer + power). I used a function generator to created a pulse at 120Hz (1.2% duty) and ~100uS (pulse width)
    The coil is:
    25 cm, 25 turns, 0.5mm wire -> 506 uH, 2.0 Ohms
    This is the pic taken from the oscilloscope; I would like to know if that is what I have to expect from the circuit; it was taken with the scope connected to the damper diodes.
  • kt315
    try now.
  • nncu2020
    I think I can't attach images :-(
    See my permits:
    • You may post new threads
    • You may post replies
    • You may not post attachments
    • You may edit your posts
  • nncu2020
    i click GO ADVANCED and choice paperclip sign above in message. do that.
    Can you please add and screenshot to see where is the paperclip?
  • nncu2020
    I don't see the paper clip
  • kt315
  • nncu2020
    Hello everyone,
    How can I attach photos to my post?
    Thanks.
  • kt315
    Originally posted by TufaN View Post
    Congratulations on your KT315. The dp layout works really well. very stable and very good underground depth. 1st video coke coke box 90x90 cm bobbin test 180 cm. 2nd video 1 euro 13 cm coil 40 cm
    good. congruts. but pls do your video horizontal. thats simple amigo! just TURN your iphone on 90 grades!
    JUST TURN YOUR CAMERA ON 90 GRAD -!
  • kt315
    RX***, not TX
  • kt315
    you must see a TX signal on output of preamp. you must get an oscilloscope to reseach signals.
    you must set pots in position according the Instruction and DO NOT TOUCH THEM ANYMORE -!
  • mk22000
    Kt as i try to find out what?s happening the detector working now with coil connected by now the problem is i try to detect a metal object with no luck.it doesnt do anything,so what to check now buddy?i open it and sounds like before as it should i lower the pontesiometers until it stays quiet but when i pass objects didn?t detect them..☹️
  • kt315
    your problem is not shield. if your MOSFET is burnt then if you connect a coil you get 'short circuit' between power lines.
    your power supply goes out and :::: no sound.
    at first stage i recommended do NOT solder MOSFET in board (Point 7 of the instruction). to check T3 signal on 'is' and then only solder transitor.
