Originally posted by Andy_F
You are forgetting about PN junction capacitance.
A reverse biased diode is equivalent to an open switch at DC, but it has capacitance. That is why varactor (tuning) diodes work.
When you reverse bias the diode, there is essentially no DC current flow - but the junction capacitance varies with reverse voltage.
Without this effect FM radio technology would be in the stone age. There would be no CDMA cell phones or frequency hopping.
This capacitance is in series with the FET capacitance, and is useful because it reduces overall capacitance during flyback.
A typical Fast Recovery diode will have a whole lot less capacitance than the drain capacitance of an IRF740 FET.
The total capacitance seen looking back into the FET will be much lower when the diode is added in series.
Now, you are right about the 0.7V drop affecting charge time. But for target illumination we are mainly concerned with discharge time.
Exactly how much faster the flyback occurs will depend on several factor. Coil and FET used will affect how much difference adding a diode
will make, but I believe (from my limited testing) that you will see the most substantial decrease in flyback times when the coil current
is at relatively lower values. If you are pulsing three or four amps you will see little difference in flyback time, but if you pulse 1-1/2 amps
there can be a substantial difference. Of course I have not tested all coil and FET combinations, but I don't think adding a
FR diode will ever slow your flyback rate.
Then, also by adding a FR diode you can use a higher value of damping resistor. Again, the amount of difference depends on several factors,
but can be quite substantial. I have only run limited tests, but adding a FR diode ALWAYS allows a higher damper to be used from
what I've seen. This should increase receiver sensitivity, although I don't know how to quantify the difference.
The 0.7V diode drop can be overcome by slightly lengthening the TX pulse. A very small change in timing resistance will maintain
the same coil current.
*I need to temporarily withdraw my claim of decreased battery supply current because I cannot remember my test setup to make that
conclusion. When I remember what I did I will reassert the statement and come back with proof. "I'll be back".
(I just remembered.)
