Delta Pulse
  • kt315
    Originally posted by raff33 View Post
    Hi KT315 ,
    what's about LM2577-ADJ... are you trying to get stability with ?
    if it is good please put how to connecting and many thanks
    hi. I still wait STTH1210D be arrived... can say nothing now before it will be installed.
    see you later
  • raff33
    anyone write me in PM.
    I did refuse 7909 use. but you can try it... I placed 7909 instead diodes VD8 and VD9, on their places (the diodes was been desoldered). photos I did not do.
    my mod now... converter on LM2577-ADJ... if it is working good in Milelab so I think it will be working good in DP too
    Hi KT315 ,
    what's about LM2577-ADJ... are you trying to get stability with delta pulse or not yet ?
  • szucs_g
    Originally posted by szucs_g View Post
    I've had it! I tried another battery in the DP. Something is broken inside. There is no virtual ground. E +, E-values ​​are bad. E + 2V, -E = -10.45V. The diodes are good. TL072 reversed. She began to heat up in the IRF. Because there is no pulsation. I give up the fight ... Or not? :-)
    Something must select a stable solution to +5 and-5V to develop, is not it?
    The tl072 burned out and irf840 to the boil. On Monday go to the grocery store. I buy plenty of them. Apparently consumables. :-)
  • szucs_g
  • growdude
    Does anyone have lcd kit for deltapulse?
    I need an led kit for my deltapulse
  • kt315
    Originally posted by jack View Post
    Hello kt315 and other friends
    I can not find the diode stth1210
    Please help me replace this piece
    Can I work take 1n4001 or 1n4148 ???
    Please help me
    I did some search the interchangeability... enjoy.
  • Sepid Gsm
    yes coil vibrates is well
    without coil,D9,D10,D2,D3 sound going too !
    thx for your help
  • szucs_g
    Originally posted by Sepid Gsm View Post
    I check all diodes an transistors
    this is my delta pic's
    From the part I wrote about my problems and a few step which you solved.
    The condensers for replace PP.
  • szucs_g
    I think this new version. You can choose between AutoTune or manual tune. Important parameters of the coil. Mine is 450 uH, 0.5 mm diameter insulated copper wire. I planned that this new version is drawn up, but I think the old one works just only manual tuning can not be stopped. The coil vibrates well? In theory, you can also handle. Patience ... You can! :-)
  • Sepid Gsm
  • szucs_g
    when i connect power sound going and dont detect eny metal
    I also had this problem. You have checked all the diodes and the fact that the E + and E where there is a need. I have gone to lf357 you have not noticed, and subsequently, two diodes as well. 4538 no matter what. The previous answers, read what I wrote to the lords. You will find a solution. It took me 3 months for it. IRF840 is used. Gabor
  • Sepid Gsm
  • mikebg
    Sepid, please explain the problem with words. What you measure?
  • Sepid Gsm
    plz help about this problem :
    Search, download and share files from 4shared: music, video, images, books, apk. Use advanced search filters to find favorite songs, video clips and mobile apps.
  • kt315
