Delta Pulse
  • aft_72005
    enjoy!
    hh
    Hi KT315
    THANK YOU.
  • goldmont
    i have a question..
    the capacitors at what voltage most be... and the resistors 1 w or ,5 or .25
  • goldmont
    HI i have a zip files where thw VD1 1N4148 is 1N148, the yours is correct? beecause i cant find the 1N148
  • goldmont
    Hi
    This forum is great.
    I want to work with the deloa pulse detector, i already have almost all the components.. but i cant found the D2 4538, D9- 4066 and the 1N148.. can you help me?
    The coil is conected directly to the pcb or do i need a conector?
  • ivconic
    KT315
    I agree what you said. But never mind the accu's. Not a problem to use some with much more capacity. I presume question is asked for other reason. Is it good to try to mod DP to be used with smaller coils and preferably to locate small coloured items like coins, rings and nugets? I have same ideas latelly.
    To adapt DP to be used as super sensitive nuget hunter and conshooter, why not? With coils let's say...20-25cm in diammeter. Kind a tired to make huge coils and use it only as very slow low frequency PI detector. Rising just a frequency on it is not solving problem completelly.
  • kt315
    Speaking of DP; by you opinion, is it good to clock it high, over 500Hz?
    it is strongly related to a value of accumulators you use. if you use 7 A*h you can tune your DP on any frequency and any pulse width you want of. but I use 2300 mA*h batt's. I must take care about the charge value, 500Hz does not give me an advantage. big pulse width I can use of but on a short limited time. another words you must find some compromise between your batt's charge and your working time in a field. do you agree?
  • kt315
    enjoy!
    hh
  • aft_72005
    hi,
    this is german FrontDesigner 3.0. russian translated version we used in our part of world, but easily converting in english. demo soft is here http://www.abacom-online.de/html/demoversionen.html
    Hi KT315
    Thank you , I remember and check my softwares CDS and found fornt designer 3
    Original program .
    It is instal on my computer now .
    Can you upload here (if it isnt secret) your drew panel as *. Fpl format?
    I built delta pulse at the past , I cannot construct box for it .
    Consider ,apply little change at it .
    Or send to my mail. Aft.72005@gmail .com
    Best regards.
  • Unregistered
    Guest replied
    What are you saying? At this specific DP audio level is more than good. Extra loud and good. If you dont get good audio than you made some mistake.
    Besides, i made DP according to pcb and schematic you posted long time ago. And it is working excellent, no audio issues at all. Maybe you forget to connect pins 2. and 6. on 555 and that how you got poor audio or no audio at all? Ha?
    Speaking of DP; by you opinion, is it good to clock it high, over 500Hz? To adjust parallel resistor and coil and to clock it very high.
  • kt315
    kt315, only revisions you done on this (poor) schematic is changing text style and few resistors values, ha,ha,ha! In this manner you can continue and make 100 revisions more! ha,ha,ha!!! But real question is ; are there any benefits from those "revisions"?
    the poor schematic is Deeper 8 revised in 2004 year. mine is absoliutely fresh! your manner is really ha ha ha but seems you have not a chance to see 100 revisions on Deeper
    what you SEE on my DP schematic all has been realised off. I still would like to add an amplifier. trying to connect TDA7052A. NE555 does not give good sound level.
  • Unregistered
    Guest replied
  • kt315
    Originally posted by Eugene52 View Post
    Who is unregistered ? I thought the Delta Pulse Project was completed and works perfect !! What is revision 3. or 4. ??
    Revision 2. on page 25 done by kt315 was final ??
    Eugene52
    well. it is revision 4 especcially for you
  • kt315
    Hi KT315
    Very nice panel.
    What software you utilized ?
    Best regards.
    hi,
  • erolunall
    Hello
    I saw this test videos yesterday.
    if they are true,looking very good .
    please look at videolar link.
    Raptor Metal Dedektörleri; VLF dedektör, Pulse dedektör, yer altı görüntüleme (GPR), gradyometre ve profesyonel define arama sistemleri üretmektedir.
    I dont have any more info about akrep detectors.
    Best Wishes
    Erol Ünal
  • aft_72005
    It isn’t delta pulse
    It is other good PI ,designed by our very good friend sascho .
