Delta Pulse
  • 6666
    Kt315 when I click that link this is all I get.
  • kt315
    thinking one pot/tuning was fixed. which sure do not see... I have not more pics of this DP.
  • mohandes
    why have 4 volume in panel?not 5
  • kt315
    DP is seems pretty good. not mine made...
  • kt315
    worked for me......
  • 6666
    KT315 your link does not work.
  • kt315
    why you people do not wish to learn to use effectively forum's search engine.... http://www.geotech1.com/forums/searc...earchid=194727
  • mohandes
    hi
    kt i need make coil like you , but need inner circle 28cm.
    please tell me number of turn and wire Thickness....
    i search for pcb add to dp to show depth . do you have it?
  • kt315
  • kt315
  • kt315
    do this coil. I give DIRECT LINK! http://chemelec.com/Projects/Metal-1...g/Coil-Jig.htm
    INSIDE DIAMETER OF COPPER HAS TO BE MINIMAL.
  • kt315
    the coil size is big enough for the ring size. for example, in VLF design a planar coil 28cm has RX winding size a half of the size ie 14cm.
    ONLY 14CM.
    try learn whites double field coil, decrease the size of coil. also do what written many times - decrease PRIMARY STROBE DELAY and STROBE WIDTH.
  • mrmetal
    how much size of your coil is? what size of gold is not sensitive?
    coil size is 28CM. not sensitive for one ring
  • calebsone
    i think on small gold it just may not be very sensitive like rings and maybe pure gold, but my dp with a 32cm coil gets a 14k gold ring in air 12cm to 15cm. so not very far but the ring is small and the dp is made for large stuff.
  • kt315
    Originally posted by mrmetal View Post
    hi.my dp is not sensitive for GOLD.
    What do I do ?
