TL12000
  • Originally posted by mazari View Post
    hi for all.I made a TL12000 device, but it does not sense any metal despite the availability of the required frequency and voltage.i need your help .thank you in advance
    Without an oscope about all you can do is make sure the power supplies are all correct and that none of the opamp stages are saturated. An oscope is a necessary tool for troubleshooting.
    • Thank you so much
      • Finally, the TL12000 device worked, but I faced a problem, which is that the Bu508a heats up and the device's sensitivity is weak.The frequency is set to 150Hz and the coil is 40cm 20 turns.If anyone has a solution to this issue, please let us know and thank you in advance.
          • Originally posted by haylaz0036 View Post
            Dear Daluka, this is the pcb Mohammed Nasr pcb says, this is the pcb in the video but it is not complete, can you send it back?
            How much depth is possible by using this to detect buried metals.?
            • hi GeoMax would you mind to send the orginal schematic file (.schdoc) or any other simillar
              • Hi asdf12345,
                sorry, I do not have those files as ".schdoc". I only have the files which are posted here. My design program is Diptrace
                • thank you GeoMax
                  but i cant find diptrace schematic file only there is an image PNG
                  would you mind send it here
                  • Hi ASDF12345,
                    Here is the TL12000 Diptrace schematic file. Enjoy...
                    TL12000_Rev1.0.zip
                    • Thanks a lot dear GeoMax
                      • Facebook link for those who want to make such a smd
                        https://drive.google.com/drive/mobil...-_2Au7lCPQEysQ
                          Hi ASDF12345,
                          [ATTACH]n442407[/ATTACH]
                          Thanks...
                            • Please , do you have Gerber file of new TL 12000
                              • I recently built a new TL12000 circuit. Here is the video of it. Unfortunately, I swapped the titles of the two videos. Based on conductivity, it rejects iron better than other pulse-induction metal detetors
                                https://www.youtube.com/shorts/T_gpkqXyZcY
                                https://www.youtube.com/shorts/EA3SoBjp70w
