  • I study subject the device to the author's website. Test video http://www.youtube.com/watch?v=-09HEuCwxHE it is advertising. The author says this is the video itself.
    You need a video?
    • Originally posted by Black Digger View Post
      [ATTACH]27022[/ATTACH]
      You need a video?
      Please can you explain what writes here because translator don't work... ""video.png"""
      • **Yes movie get more publicity than the reference** - a translation of the word-for-word
        • Originally posted by Daxxin View Post
          if you wanna fix now to make nice look , just put a few flux ..but a very few then with desoldering braid ( wick is a good brand) remove the excessive sold paste
          bevel tip is a good choice [ATTACH=CONFIG]26982[/ATTACH]
          Correctly apply this tip for soldering processor
          • what is thats?
            • Upper two points are RXD\TXD from MCU, not needed, probably used in development stage, can be ignored. Right 4 pins are PDI interface, novelty in Atmel series, for programming\debugging. Lower left pin is PP\ static switch for pinpoint mode.
              • I can`t wait until someone will fire up this MD I`m soe curious of his behaviour on real soil -discr, real deep and how stable he will be. And what about "Quasar Vs. KROT2-xm". Wish You all sucessfull turn on.
                • We waiting for some components yet...
                  I believe that until end of November to have complete construction and tests....
                  • Very slow delivery
                    • Mine is completed, powered up and working, soon I will be in my workshop again, will post more, pictures etc.
                      • Did you construct a new coil or you used an old one???
                          Good news from you Tepco. Eagerly avaiting your next report.
                          @Geo, I am planning to use (for start) factory 10" CC coil (and housing) from Chinese MD-3030, working at 5.9kHz (ITMD book says that there is no passive or active parts in this coil, so it can be adapted to 8kHz without opening coil housing). I got one broken MD-3030. If this perform satifactory I will build one in DD design later.
                          • What about the resistences with asterisk in the word doc component list? what the meaning?
                              this is a standart way in electronics schematics to note 'you have to tune-choice this value according your testing process at your testing stage for to get optimal stable work of your circuit'
                                @Geo, I am planning to use (for start) factory 10" CC coil (and housing) from Chinese MD-3030..
                                This is the wrong decision. By the Mole-2 sensor is needed right, not trash (from the Chinese detectors). There's even a cable, it may not like to ... And what about the balance? After such experimentation might get the wrong idea about the work of the unit ...
