    Read the thread and you will find it. It is recomended to use double sided pcb with the one side to be "ground".
    Thank's Geo.
    • Hi,
      I'm looking for a fuses programming specialist ...
      I'm trying to burn few chips with the good fuses, the write operation seems to be ok but when i read fuses after burning,
      i get the wrong value for FUSEBYTE4 (I read 0xEF instead of 0xEE).
      I'm using atmel studio with ATMEL ICE programmer. The chip is a ATXMEGA32A4.
Name:	Sans titre.jpg
Name:	Sans titre2.jpg
      The required fuses configuration is there :
      Your help would be great !! THANKS
      • No need extra fuses configuration . I use avrstudio 4 /AVR Studio 4.19 and up/ and avrisp MKII . Mole in programing mode power from USB , reset and everything works .
        • Originally posted by timekiller View Post
          Ok, thanks but at the bottom of the author's page, there is a screen copy of the fuses with FUSE0=0xFF, FUSE1=0x00, FUSE2= 0x7F, FUSE4=0xEE and FUSE5=0xEA
          http://radiodom.org/index/selektivnyj_mikrokontrollernyj_metallodetektor_quo t_krot2_m_quot/0-17
          • My MCU is ATXMEGA32A4-AU . Screen copy of the fuses shows ATXMEGA32A4 , they are different MCU
            • My unit works good. There was a bad soldering joint on the MCU ...
              I'm getting lost with all those differents MCUs and fuses ...
              Tomorow, i'll build the coil and let's go for the rush !!
              • Hi,
                I just finished the whole detector. The coil isn't filled with epoxy till it's not tuned properly.
                I woul like to have advises about the tuning methode.
                I built the coil like this :
                TX: 45turns of 0.4mm magnetic wire (L=1.06mH, R=3.6ohms) C= 300nF
                RX: 200turns of 0.15mm magnetic wire (L=22.8mH, R=127ohms) c=22nF
                I noticed that in the setup menu, there is an aututune function. It gives me 9389HZ.
                On the oscillocope, i can see the DAC SIN output very clearly. The output of the output AMP is about 2 volts (AC).
                Now, i don't realy know how to tune RX circuit. Could someone explain me the differents steps ?
                I can help people programming chips but i don't have successfull experience on coil nulling for the moment.
                I'll share pictures later..
                Thanks a lot for any help
                • RX is auto Tunne coil without resonance . Before starting work with the device RX and TX must be set up abaut max 0.2 v on gain 2 ,HPF4 . I think that L=1.06mH It is too small inductance for Tx . 1:10 inductance should be properly. There are various methods for setting the Rx Tx . The most simple is shifting to one another .
                  • OK, thanks for info,
                    For the TX inductance, i use the one from post #8.
                    When you say that "RX is auto Tunne coil", do you mean that the capacitor for RX is not needed ? I have to make more tests on this.
                    What does HPF means ?
                    I have a word file but google translator is not so accurate ..
                    • For RX is not needed extra capacitor. Changes only C1 and get different frequencies . HPF in menu - this is the level of sensitivity. For room test recomendet set 4 .
                      • Mole-2 is now able to work on two frequencies simultaneously! Details here. http://www.radiodom.org/index/krot2_dfkh/0-21
                        • A big thank you to Reptooyep for his help in programing my chip for me. Next step coil building. !!!
                          • PCB complete
                            • You have no mole sensor shows 300 mV? This is bad! It must be near zero. Look for errors, and wash the PCB.
                              • There is no coil yet. Is that why ? I shall look for errors tonight.
