Originally posted by kt315
View Post
Ferrous and no-ferrous
Originally posted by satdaveuk View PostI agree with Joop
If in a really junky location Induction balance is the way to go, However you will still be digging junk but not quite so much unless your like me because I tend to dig almost everything hence the bad back
Joob right.
I'll ride one TGSL in a few weeks. Today I continue to study its performance.
I have not ridden before because I'm a bit poor ($ $ $ $ $ $ $).
When finished with the TGSL want TINKERER-model mount.
TINKERER seems like a great idea. It's a different concept.
And when finished with the TINKERER want to ride someone else.
Gradually I want to try several models.
Meanwhile I will continue with my tests. All my life I'll be doing tests.
Thanks Satdaveuk. My weary bones are grateful. :-)
Regards.
Hello, I 'm happy for the PIC . :-)
If you are interested in further testing will be interesting this other code.
Change the scheme, but has some advantages.
- Did not use the NE555 .
- The PIC generates a signal with an initial period of 98 uS and a pulse width of 10 uS.
- With the " d " key pulse width is increased.
- With the "f " key pulse width decreases.
- The minimum pulse width is 1.8 uS.
We use the two bytes of ADC capture . ADRESL and ADRESH .
By PORTB only see ADRESL .
We debbug output console. I use Hyperterminal but there are many others.
It should be set as follows: 9600 8n1 Xon / Xoff
In RB 873 pin 7 is RX and RB pin , 6 is TX .
I use a USB to TTL converter like CP2102 USB port.
MAX232 , MAX233 , serial ports etc for COMxx also available.
We see this in the console : " xxx + ADC and ( zzz * 400ns ) uS " + CR
where :
- . Xxx = ADRESL in dec
- . Y = ADRESH in dec
- . Zzz = VALOR_A in dec
Like this :
To upload VALOR_A press "a" key
To download VALOR_A keypress " s "
The minimum tripping time is 600ns ADC and the maximum time is 102 uS.
Keep in mind that the time of each catch is 19.2 uS with a 20 Mhz crystal .
With this code I learned a lot . I hope you serve .Attached Files
Originally posted by 6666 View PostHi alber_gold
Thanks for the information on new design.
Could you please tell us the new coil information Ltx/Lrx and what value is C1, thanks
6666
Hello, happy 2014.
I have tried many different coils and I can not pinpoint any particular.
You can try different coils and study their behavior.
You can also use a single coil.
56 ohm resistor. protects the transistor.
You can change to increase reach but not exceed the maximum voltage of a transistor CE.
I put C1 for options in the output signal. Different ways with different values.
Typically work without any capacitor.
